kingy444 117 Posted March 19, 2016 Posted March 19, 2016 Hello All, Just enquiring on the "Automatically convert recordings to a streaming friendly format" setting on the Live TV Section of EMBY. I have the setting enabled -> and using the default recording path but it isnt converting the wtv files that windows media centre creates. Is this a known limitation. Auto Update on current build, never tried the feature previously
Luke 42242 Posted March 19, 2016 Posted March 19, 2016 This only applies to recordings from the built-in live tv features, not windows media center. if you'd like to convert recordings created by other software, check out the Folder Sync plugin: https://github.com/MediaBrowser/Wiki/wiki/Folder%20Sync
kingy444 117 Posted March 19, 2016 Author Posted March 19, 2016 so just so I understand, setup foldersync to move the recordings from ServerWMC to the path I specify in that setting page? Then EMBY will convert them?
kingy444 117 Posted March 19, 2016 Author Posted March 19, 2016 and if my assumption above is correct, wouldnt putting the same recording path for both achieve the same outcome?
