unclemutt 0 Posted March 19, 2016 Posted March 19, 2016 Hello, Trying out Emby on my Mac (OS X Lion 10.7.5, 3.06 GHz Intel Core 2 Duo) so see if better than on my ubuntu server with a slower CPU than this. Look around 8:33am today on the log file. Using web browser on the same mac. I have also tried a couple days ago on my iOS device as well as android tv with the same errors in the log. I can playback the same files through VLC fine. I had installed ffmpeg separately as I thought that may have been the issue looking through similar issues on this forum. Same errors on the log on playback before and after the ffmpeg install. Thanks Mike Log.txt.zip
Luke 42237 Posted March 19, 2016 Posted March 19, 2016 Hi, unless I'm missing something, that log actually looks fine, no?
unclemutt 0 Posted March 19, 2016 Author Posted March 19, 2016 Try around here, thanks: 2016-03-19 08:33:40.2064 Debug App: Disposing stream resources2016-03-19 08:33:40.2109 Info App: FFMpeg exited with code 1322016-03-19 08:33:40.3746 Debug App: Waiting for 3 segments in /Users/stewartimac/.config/emby-server/transcoding-temp/9282777811744941bd6b944923623168.m3u82016-03-19 08:33:40.4343 Error DtoUtils: ServiceBase<TRequest>::Service Exception *** Error Report *** Version: 3.0.5882.0 Command line: /Applications/Emby.Server.Mac.app/Contents/MacOS/Emby.Server.Mac -psn_0_55735588 Operating system: Unix 11.4.2.0 Processor count: 2 64-Bit OS: False 64-Bit Process: False Program data path: /Users/stewartimac/.config/emby-server Mono: 4.2.2 (explicit/996df3c) Application Path: /Applications/Emby.Server.Mac.app/Contents/MonoBundle/Emby.Server.Mac.exe Could not find file "/Users/stewartimac/.config/emby-server/transcoding-temp/9282777811744941bd6b944923623168.m3u8". System.IO.FileNotFoundException at System.IO.FileStream..ctor (System.String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize, Boolean anonymous, FileOptions options) <0x445b368 + 0x00663> in <filename unknown>:0 at System.IO.FileStream..ctor (System.String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize) <0x4711f30 + 0x00043> in <filename unknown>:0 at (wrapper remoting-invoke-with-check) System.IO.FileStream:.ctor (string,System.IO.FileMode,System.IO.FileAccess,System.IO.FileShare,int) at CommonIO.ManagedFileSystem.GetFileStream (System.String path, FileMode mode, FileAccess access, FileShare share, Boolean isAsync) <0xbc5a460 + 0x000b3> in <filename unknown>:0 at MediaBrowser.Api.Playback.Hls.BaseHlsService.GetPlaylistFileStream (System.String path) <0xd747b40 + 0x000a7> in <filename unknown>:0 at MediaBrowser.Api.Playback.Hls.BaseHlsService+<WaitForMinimumSegmentCount>c__async1.MoveNext () <0xd7474c8 + 0x00137> in <filename unknown>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () <0xd6af230 + 0x0002b> in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) <0xd6aefc8 + 0x000b3> in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) <0xd6aef28 + 0x00083> in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) <0x65f5330 + 0x00033> in <filename unknown>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () <0x65f5308 + 0x00013> in <filename unknown>:0 at MediaBrowser.Api.Playback.Hls.BaseHlsService+<ProcessRequestAsync>c__async0.MoveNext () <0xd6a9168 + 0x008eb> in <filename unknown>:0 2016-03-19 08:33:40.4408 Error HttpServer: Error processing request for /emby/videos/2060c450fbff15a282f82794f07f8451/live.m3u8?DeviceId=bc4fc11871bf8f3a4182ebeb25f99769d0f1ee8a&MediaSourceId=2060c450fbff15a282f82794f07f8451&VideoCodec=h264&AudioCodec=aac&VideoBitrate=164841290&AudioBitrate=320000&MaxAudioChannels=6&Level=41&Profile=high&PlaySessionId=1dec101d3f9d4958bf850e7ac3d0c0f2&api_key=fc770d37487443d0ad282e0d979c054d&CopyTimestamps=false *** Error Report *** Version: 3.0.5882.0 Command line: /Applications/Emby.Server.Mac.app/Contents/MacOS/Emby.Server.Mac -psn_0_55735588 Operating system: Unix 11.4.2.0 Processor count: 2 64-Bit OS: False 64-Bit Process: False Program data path: /Users/stewartimac/.config/emby-server Mono: 4.2.2 (explicit/996df3c) Application Path: /Applications/Emby.Server.Mac.app/Contents/MonoBundle/Emby.Server.Mac.exe Could not find file "/Users/stewartimac/.config/emby-server/transcoding-temp/9282777811744941bd6b944923623168.m3u8". ServiceStack.HttpError No Stack Trace Available 2016-03-19 08:33:40.4441 Error NotFoundHttpHandler: 192.168.1.13:8096 Request not found: /emby/videos/2060c450fbff15a282f82794f07f8451/live.m3u8?DeviceId=bc4fc11871bf8f3a4182ebeb25f99769d0f1ee8a&MediaSourceId=2060c450fbff15a282f82794f07f8451&VideoCodec=h264&AudioCodec=aac&VideoBitrate=164841290&AudioBitrate=320000&MaxAudioChannels=6&Level=41&Profile=high&PlaySessionId=1dec101d3f9d4958bf850e7ac3d0c0f2&api_key=fc770d37487443d0ad282e0d979c054d&CopyTimestamps=false
unclemutt 0 Posted March 19, 2016 Author Posted March 19, 2016 This is earlier in the file and was not sure if related to my playback error or not: 2016-03-19 08:32:20.9898 Warn App: ffmpeg is missing decoder h264_qsv 2016-03-19 08:32:20.9898 Warn App: ffmpeg is missing decoder mpeg2_qsv 2016-03-19 08:32:20.9898 Warn App: ffmpeg is missing decoder vc1_qsv 2016-03-19 08:32:21.3512 Warn App: ffmpeg is missing encoder libx264 2016-03-19 08:32:21.3512 Warn App: ffmpeg is missing encoder libx265 2016-03-19 08:32:21.3512 Warn App: ffmpeg is missing encoder mpeg4 2016-03-19 08:32:21.3512 Warn App: ffmpeg is missing encoder msmpeg4 2016-03-19 08:32:21.3512 Warn App: ffmpeg is missing encoder aac 2016-03-19 08:32:21.3512 Warn App: ffmpeg is missing encoder ac3 2016-03-19 08:32:21.3512 Warn App: ffmpeg is missing encoder libmp3lame 2016-03-19 08:32:21.3512 Warn App: ffmpeg is missing encoder srt
Luke 42237 Posted March 19, 2016 Posted March 19, 2016 yea looks like an issue with the ffmpeg build.
unclemutt 0 Posted March 20, 2016 Author Posted March 20, 2016 Well I got it working... Downloaded the latest ffmpeg and ffprobe files from www.ffmpeg.org for my version OSX and replaced in ../.config/emby-server/ffmpeg/20160124/ Thanks Mike
Luke 42237 Posted March 20, 2016 Posted March 20, 2016 Well done Where exactly did you download from?
unclemutt 0 Posted March 22, 2016 Author Posted March 22, 2016 www.ffmpegmac.net link within www.ffmpeg.org Works good for the playback so far but no success with the mp4 conversion. Does anyone have OS X Lion and install ffmpeg using Macports or Homebrew? I'm wondering if compiling my own is the way to go. Is a symbolic link recommended?
Luke 42237 Posted March 22, 2016 Posted March 22, 2016 That's the same build we're using for osx 32-bit. 64-bit comes from here http://www.evermeet.cx/ffmpeg
unclemutt 0 Posted March 27, 2016 Author Posted March 27, 2016 Thanks. Is there a separate Emby install for 64-bit OS X?
