Feature request: Restart emby theatre in settings
Ineedanewname
Hi, as I use emby theatre with a remote it's a bit of a pain to exit emby and then use a different device to start it again to get the latest update. It would be great if there was an option to restart emby from the settings section.
Similarly, it would also be good if in the menu which allows you to go to settings and exit emby if the choice to restart and shutdown the computer was available.
Regards,
Rohan.
Sent from my Nexus 9 using Tapatalk
Hi, yes this is a good idea.
  • Like 1
Jack Burton
I'm using a harmony remote and have a button mapped for emby theatre (using Windows 7). The ET shortcut is the 4th program on my taskbar, so one button is mapped as WIN+4. Works to launch it.
Ineedanewname
I didn't realise you could do this until I saw another post re harmony remotes. I prefer a restart menu item, but it does give me some other ideas though. Thanks.
