Emby for Kodi on Android TV box - not loading all folders?
Sorry in advance for the long winded question.
I am currently using Emby (latest version) for Kodi (16.0) on my Android TV box but for some reason it will not populate one media folder.  I have my collection split up as such (all files are .mkv):
Kids
Movies
TV Shows
Sports
Comedy
Documentaries
Music Videos
Other
All of these folders get populated within Kody with the exception of 'Kids' and I don't know why?  I can view and play all of the 'Kids' movies within the 'Movies' folder, but when I select the 'Kids' folder it is blank...makes putting on a movie for the little ones WAY more work than it should be ;).
I would use the Emby Android app but for some reason it doesn't like certian .mkv files and won't play the sound whereas within Kodi it does (another separate issue maybe?)...  As a side note, the 'Kids' folder in the Android app populates correctly (as well as all my other devices).
Any advice or input would be appreciated!
Angelblue05
Go to the webclient > user icon > settings > home settings > my views. Make sure kids is not grouped (checkbox should be unchecked)
Sent from my iPhone using Tapatalk
Guest
