jason66048 0 Posted March 16, 2016 Posted March 16, 2016 Just wondering what the best option is when dealing with encrypted LiveTV cable? Been running WMC since the XP era for LiveTV and Kodi for the media library. For the past few months been exploring options and Emby seems like a great one source solution that is wife friendly. Would it be better to use Emby for WMC, pull media from server, and continue to run Live TV though WMC since I have encrypted Live TV? Or should I consider another option using ServerWMC as I understand the Emby Server along can’t decrypt encrypted LiveTV cable? Any incite would be great. Thanks.
mjktg99 35 Posted March 17, 2016 Posted March 17, 2016 Encrypted tv won't work at all with emby. Wmc is currently your only option.
jason66048 0 Posted March 17, 2016 Author Posted March 17, 2016 I figured WMC would be my only option. Would you know if Emby for WMC would work? My understanding is that Emby for WMC is an add on program to WMC. So then I could pull media from my media server and just continue to run encrypted Live TV though WMC? Thanks for your time.
ebr 16335 Posted March 17, 2016 Posted March 17, 2016 Emby for WMC will work fine but it won't present Live TV from the server. You would just continue using the standard WMC Live TV interface.
