tarnalcock 4 Posted March 16, 2016 Posted March 16, 2016 Hey guys, The new theater refuses to open when my pc is offline. I simply get a big black screen. Looking at the logs it seems to be task connecting to github for updates and failing - which is halting the entire startup process? I tried messing around in the config files, turning some autoupdate directive to false. This did not help. But it also appears that the new theater doesn't clean up the remnants of the old theater very well, so maybe those configs are unused? Either way, log file is attached. I can confirm that theater opens without complications or hiccups when online. I have another folder "C:\Users\Tarn\AppData\Roaming\Emby Theater". Is this a remnant from the old theater? Can it be cleaned up? TIA Tarn theater-63593573973.txt
ebr 16335 Posted March 16, 2016 Posted March 16, 2016 Will Emby Theater require constant internet connection?
