Aeon Nox Problem with Background images on main menu
Hi
I'm using the latest beta I'm having an issue; now i dont know if this is even supported but it used to work until a few betas ago.
On my Main Menu of Aeon Nox i set the Background Image for some of my Menu Headings (Movies, TV etc) to Random Movie fanart, Random TV show Fanart or just Randon Video Fanart and that used to work fine but now all i get is a Black screen though occasionally an image does appear then goes back to black.
This is from the log (this is using a remote address as i'm at work but does the same on my local network with the artwork cached)
11:25:26 T:9444 WARNING: XFILE::CDirectoryFactory::Create - unsupported protocol(image) in image://http%3a%2f%2fnawo69.no-ip.org%3a8096%2femby%2fItems%2f274e598525d98c99cd9daeb86b6e7c73%2fImages%2fBackdrop%2f0%3fMaxWidth%3d10000%26MaxHeight%3d10000%26Format%3doriginal%26Tag%3da7b4404d654ec48f2f73328f71a5bf7e/
11:25:31 T:15164 WARNING: XFILE::CDirectoryFactory::Create - unsupported protocol(image) in image://http%3a%2f%2fnawo69.no-ip.org%3a8096%2femby%2fItems%2f1642241dd368f8762f4619758ee2c627%2fImages%2fBackdrop%2f0%3fMaxWidth%3d10000%26MaxHeight%3d10000%26Format%3doriginal%26Tag%3d1912ce1b237236ff08204847423500bf/
The way I'm setting them is :-
System,Appearance,Skin, Settings, Setup the Aeon Nox main menu, then selecting a heading,set item background, then choosing one of the above options
Is this not supported any more or am i doing something wrong?
And thanks for this brilliant add-on I switched over from Plex and haven't looked back.
Guest
