ozchef 3 Posted March 16, 2016 Posted March 16, 2016 When I play movies its only showing a couple of my trailers I have trailers for most of my 1000 odd movies. Is there a way of adjusting this or to make it use 1 at random instead of the same trailer for the same movie time and again?
Solution jordy 284 Posted March 16, 2016 Solution Posted March 16, 2016 There is a tab for "Cinema Mode" under "Playback" on the server settings page. you can specify the number of trailers to play and also where they are sourced from 1
ozchef 3 Posted March 16, 2016 Author Posted March 16, 2016 Thats how i have it set up and still get the same 10 odd movies as trailers. I have it set to 1 trailer before movies
ebr 16307 Posted March 16, 2016 Posted March 16, 2016 Thats how i have it set up and still get the same 10 odd movies as trailers. I have it set to 1 trailer before movies It tries to pick a trailer that is relevant to the movie being watched. So, if you are watching the same movie - or similar ones from the perspective of genres - then you will see some of the same trailers.
ozchef 3 Posted March 16, 2016 Author Posted March 16, 2016 Is there a way for it to pick at random? Its picking of similar is quite awful.
Koleckai Silvestri 1154 Posted March 16, 2016 Posted March 16, 2016 Is there a way for it to pick at random? Its picking of similar is quite awful. A lot of the functionality was lost when they abandoned the plugin. Make sure everything is checked except for "Only Use trailers from unwatched content"
Luke 42186 Posted March 20, 2016 Posted March 20, 2016 I sure do miss that plugin What is missing from the built-in cinema mode? Perhaps file a feature request containing something that is important to you? Thanks!
gcastro000 0 Posted March 21, 2016 Posted March 21, 2016 When I rip a movie, I usually get a few trailers from other movies. Is there a way to see those trailers automatically when I start watching the movie?. I think the minimum use cases would be: 1. There should be an option to watch the trailers in the directory of the movie 2. Another option to watch the trailer of the movie automatically 3. An option in the client to skip the trailers
bluemonkey07 590 Posted March 21, 2016 Posted March 21, 2016 (edited) 2. Why? If you want to see the trailer for the movie you are watching you should be able to select it on the items details screen before choosing to play it 3. Most clients now have the option to disable cinema mode for just that client Edited March 21, 2016 by Vidman
bluemonkey07 590 Posted March 30, 2016 Posted March 30, 2016 (edited) OK I'm trying out cinema mode again and only want local trailers (which I have for some movies ... (Before the plugin stopped allowing them to be downloaded) but when set like this I have no trailers, however if I enable any of the streaming options it works (kind of... Constant buffering due to sh!t internet) . I have tried this on the android app, web client , the new theatre and kodi addon all behave the same, server version freenas 3.0.5911.0 Edited March 30, 2016 by Vidman
Luke 42186 Posted March 30, 2016 Posted March 30, 2016 I'm looking at this for the next release, thanks.
