jscoys 147 Posted March 15, 2016 Posted March 15, 2016 Hi, I think usage of tags is really a great value in Emby, but today it's not used at its plain potential I Think. Two things about Tags : - Allowing the use of Tags into search and/or into a special View listing all tags available. Excepting if I'm totally wrong, I can't search all movies with tags "superhero" today... - When I want to disable access to specific movies to a specific user, for instance my little kid, I have to enter infos about tags forbidden into parental control. But If I want to disable access to "American Pie" and "Orgazmo", the first one have a tag "teenage sexuality" and the second one "Sex". Why don't allow the ability to define a "Contains" option? With that I would be able to say "All tags containing "Sex"" and my problem here is resolved. So a little dropbox with options "Is" and "Contains" would be great... What do you think about it? 1
the-dumb1 135 Posted March 15, 2016 Posted March 15, 2016 The "special view listing" is already implemented. If you click on the "Movies" tab, then click on the weird looking "down" icon (the one next to the A/Z icon), you're presented with a way to filter the listings (including filtering via tags).
jscoys 147 Posted March 15, 2016 Author Posted March 15, 2016 Oh yeah indeed you're right! But it still the second feature for a "Contains" option! Sent from my iPhone using Tapatalk
Deathsquirrel 745 Posted March 15, 2016 Posted March 15, 2016 I would think ordinary parental controls based on ratings would address keeping an R and NC-17 movie out of your kid's queue far easier and more reliably than using tags. 1
jscoys 147 Posted March 15, 2016 Author Posted March 15, 2016 I think it could bring a better way of tweak content access without a lot of effort...
Redshirt 1487 Posted March 15, 2016 Posted March 15, 2016 tags in search results would be the bee's knees.
anderbytes 141 Posted March 15, 2016 Posted March 15, 2016 If also new content could be auto-tagged would be great. In my case, I wish that no content gets visible to common users until a tag "REVISION" exists in that media. That would allow me to only release something (remove the tag) when it's full revised (parental ratings, description, title, genres, etc....etc....) That would also require that media specific tag can be hidden from libraries.
WebSpider 0 Posted March 18, 2016 Posted March 18, 2016 I would think ordinary parental controls based on ratings would address keeping an R and NC-17 movie out of your kid's queue far easier and more reliably than using tags. This would be true for US parental controls, however non-US content usually has local parental controls, which is a whole different set of categories. Here tags would really help.
ebr 16307 Posted March 18, 2016 Posted March 18, 2016 This would be true for US parental controls, however non-US content usually has local parental controls, which is a whole different set of categories. Here tags would really help. We fully support other rating systems in our parental controls. What system are you using?
anderbytes 141 Posted March 18, 2016 Posted March 18, 2016 We fully support other rating systems in our parental controls. What system are you using? Hi @@ebr, I need to say something about the parental rating system support. Here for Brazil it exists BR-L, BR-10, BR-12, BR-14, BR-16 and BR-18. - The list could be editable (ex: I need to create something as BR-6, BR-8, or hide native BR-16), and sort them however I like. - As asked in other topic. The CUSTOM RATING should be a column togglable in REPORTS. - The ratings don't have descriptions anywhere. That's what I remember just now. Tnx
jscoys 147 Posted March 18, 2016 Author Posted March 18, 2016 The "special view listing" is already implemented. If you click on the "Movies" tab, then click on the weird looking "down" icon (the one next to the A/Z icon), you're presented with a way to filter the listings (including filtering via tags). As timid1 said "special view listing" is already implemented, but not totally. @@Luke their is a bug that prevent to display the whole tags list as you can see on this picture. Tested in Web (Chrome) and IOS. In this state this "special view listing" is not usable. Sent from my iPhone using Tapatalk 1
WebSpider 0 Posted March 18, 2016 Posted March 18, 2016 We fully support other rating systems in our parental controls. What system are you using? I've been trying to get ratings for the Dutch Kijkwijzer system (ratings such as AL, 6, 12, 18 and tags like 'violence', 'sex', 'fear', 'drugs') implemented, with very limited success. The icons, I can find. The grabbing of ratings online has unpredictable successes, and getting them in the dropdown, I can't figure out. This may offcourse just be my limited googling skils :-)
Luke 42186 Posted March 18, 2016 Posted March 18, 2016 it would be nice to have them configurable, but in the meantime, you can submit a pull request and add additional entries for your language here: https://github.com/MediaBrowser/Emby/tree/master/MediaBrowser.Server.Implementations/Localization/Ratings If you don't know how to submit a pull request then make a public topic and allow others to help you.
