Advice for QNAP users on hard drive setup
gillmacca
Seem a bit confused with my new server, previous one was ReadyNAS NV+, which was easy to set-up.
Just got myself a QNAP TS-451+.
Disk 1(which is ssd), that will contain the QNAP OS, Emby, and some other apps.
Disk 2 will be for TV
Disk 3 for Movies
Disk 4 for everything else
I want to use maximum storage space, no redundancy (everything is backup up to external hard drives).
If for example, the tv Hard drive fails, I want to be able to take it out, put a new hard drive it, and restore from my backup.
At the moment, I only have the 2 hard drives (3rd one coming tomorrow)
Under storage space, it says static single volumes, and then lists my HD's, but if I select manage, it mentions raid group 1
Is this set up correctly, for what I want? If not, how should I be setting it up (step-by-step guide, if possible)
Thanks for your help
legallink
This might be better asked in a QNAP forum, as they will have more expertise with the QNAP software, but the minute it mentions a Raid group, is the minute that whatever drives are associated with that group will be viewed as 1 drive, not separate drives.
If you have a 4 drive Qnap and you want the 4 drives viewed separately, you should disable any sense of Raid, as Raid is intended to duplicate files so you have drive fault tolerance (aka a drive crashes, you put in a new drive and it just rebuilds the old drive).
