geoffishere 0 Posted March 13, 2016 Posted March 13, 2016 Hi Sorry this is a bit vague. Basically i am having intermittent issues with my mobile apps. I have a ipad mini and a amazon fire and they both suffer bouts of losing connection.When i click on a link i just get the loading circle this happens for a few minutes and then connectivity is fine- I can load a web browser on the devices during this time and connect to google.co.uk so connection seems fine. This is when i am at home on the same network as my server. I also have a wired connection to a wetek openelec box running the emby plugin- this seems to be fine and i can also access the server over the wireless from my laptop during this time. I would point my finger at my router but i dont have issues with anything else I am running emby as a docker on a unraid server. I have attached a debug log - if you want one over a shorter period let me know. Log.txt
Luke 42243 Posted March 19, 2016 Posted March 19, 2016 Hi, welcome. did you solve this? i notice you only have a dual core server with a number of plugins installed, and it's reporting some slow response time to emby apps. can you try removing all plugins and then seeing if the issue persists? thanks!
geoffishere 0 Posted March 20, 2016 Author Posted March 20, 2016 Hi, I have just upgraded to a quad core intel i5 but still having the issue. I will try removing all plugins and see if that helps- will report back in the next day or so cheers geoff
