mjktg99 35 Posted March 13, 2016 Posted March 13, 2016 Scenario; main tv has a roku or other stb that is used by all. That emby account is restricted to pg only. Instead of changing accounts in emby, could there be a prompt for a pin to access pg13 + content? I've seen this on a cable box back when I used to have them. 2 3
ebr 16337 Posted March 13, 2016 Posted March 13, 2016 The cable box worked that way because it had no concept of different users. MB 2 used to work this way too but, when we designed Emby around users we went away from that model - and no one has really looked back since. One thing I can suggest is that you can use another device logged into a user with proper access to send the video to the device that doesn't. So, you could bring up the web browser in your phone and play whatever you want to the Roku.
anderbytes 141 Posted March 13, 2016 Posted March 13, 2016 +1 for mjktg99 and his "private content" :-d *naughty*
mjktg99 35 Posted March 13, 2016 Author Posted March 13, 2016 +1 for mjktg99 and his "private content" :-d *naughty* Not at all what I am talking about (that stuff is only accessible to my account anyway) because in this scenario, that stuff would still be visible just not playable. Which is what I'm after. I have the best 5yr old son who doesn't have to wake me up at 7am on the weekend I just don't want him to be playing an r rated movie because he knows hes not allowed. At some point, that rule follower will replaced by the rule tester. @@ebr as an aside and this may already be a feature that I'm not using because I hide all my users from the log in screen, is there an option to save the password? So it can work more like Netflix where I pick the profile but I don't need to sign into the account everytime?
anderbytes 141 Posted March 13, 2016 Posted March 13, 2016 I was only joking. I also have a small child and I know exactly what you're saying. What I did was create a user for him and make it passwordless inside home network. And make his account very restricted.
mjktg99 35 Posted March 13, 2016 Author Posted March 13, 2016 What I did was create a user for him and make it passwordless inside home network. And make his account very restricted.I'm just trying to make it as easy as possible to get to my content or switch user. Putting in a password every time with a 6 button remote is annoying..
anderbytes 141 Posted March 13, 2016 Posted March 13, 2016 Maybe devs can create a way so another kinds of password input are possible. Patterns like Android, maybe? Imagine if what you said was implemented. Me as the mais user and unrestricted would have to input a pass everything something different than PG needs playing...
bluemonkey07 590 Posted March 13, 2016 Posted March 13, 2016 (edited) If you give your account an easy pin for local access , changing to your account/another user should be almost as simple as entering a pin to access restricted content Edited March 13, 2016 by Vidman
mjktg99 35 Posted March 13, 2016 Author Posted March 13, 2016 If you give your account an easy pin for local access , changing to your account/another user should be almost as simple as entering a pin to access restricted contentI just looked at those settings and it might give what I want. Thanks for the suggestion @@Vidman
Happy2Play 9812 Posted March 13, 2016 Posted March 13, 2016 In the end you are still logging in and playing media on an account with full access. ebr's "play to" option is more realistic for the scenario. 1
mjktg99 35 Posted March 14, 2016 Author Posted March 14, 2016 In the end you are still logging in and playing media on an account with full access. ebr's "play to" option is more realistic for the scenario. yeah. I just tried the pin and switching accounts. It's to cumbersome for what I'm used to and looking to do. I'll have to try the play to option..
ebr 16337 Posted July 12, 2023 Posted July 12, 2023 In part of our authentication improvements, we plan to do a variation of this that will hopefully satisfy the request. Our plan is to add an optional additional layer of access security to accounts with a PIN. So, you would designate a particular account always needs to provide that PIN for access.
Jey2024 33 Posted April 3, 2024 Posted April 3, 2024 I was actually checking online for this feature and stumbled upon this existing feature request. I just wanted to share my thoughts, but they're slightly different from what has been reported here. If I should move this idea to a different thread, please let me know. I would really love to see some sort of restriction on libraries. I like to categorize my media in different folders and create separate libraries. Let's say I only use my Android phone to stream from Emby, and I have a library with some TV series rated PG-13. If my kid takes my phone to stream some cartoons that I downloaded for him, I wouldn't want him to accidentally open my TV series library. When we click to open, maybe it could ask for a 4-digit pin, etc. I know it could cause annoyance to re-enter the pin every time, and I do understand it's not something easy to implement. But, rather than logging out of my account and logging in using another restricted account, any sort of pin/password or hidden library section would be beneficial for those who share their devices with kids. It's just my two cents. Huge respects to the developers, but such a protected library feature will surely come in handy. Thanks for your time.
rbjtech 5344 Posted April 3, 2024 Posted April 3, 2024 This goes against the general policy of getting access based on your login/user. A much better solution is simply to improve the ease on which others can login to ANY device and automatically get the same level of access. If you child uses your phone, opens emby and is presented with a list of previously logged in (but saved) users - then that is ultimately the way emby needs to work on all devices. If you want to restrict access on shared devices, then you simply put a PIN on those accounts during login (needed once per login). Your child would not need a PIN, they could just select themselves - and then see the same content, played items, history etc as they would if they had used that same account on their bedroom TV (for example). If you wish to restrict an entire library, then you simply do that at a 'user' level - or do it via the rating system (again, all User based). The new Authentication methods that emby has recently introduced, allows this to work with all devices incl remote - thus, this is now a real possibility to login on ANY device and get the exact same user experience.
Betonhaus 18 Posted December 30, 2024 Posted December 30, 2024 It would be nice if we could define a library as "restricted" where: 1. Newly created accounts do not have access to it by default even with "all libraries" checked, as adding it requires an additional check 2. Those that do have access to the library do not have it's contents show up on suggestions in the play next or continue watching 3. That library is hidden from search, and otherwise it's contents do not show up unless you are viewing the library directly 4. If possible, make the restricted folder semi hidden, where accessing it requires a couple other steps like entering a pin code. 5. Possibly have the ability to disable IMDB/TVDB/etc metadata search and go solely by file names This would be useful for using Emby to share private or confidential content with some accounts while ensuring that they are not seen by other accounts, and so when the allowed accounts are being used in a shared place the contents stay hidden unless directly accessed. This could be used for sharing confidential business content such as training videos or cherished family memories that you want to be visible only for trusted family members, or there could be other scenarios where this would be useful. And while just telling people to create different accounts is fine and dandy, ultimately there will be times when people are watching content together or passing a device that's logged onto their account already to someone that's likely not going to go switch accounts, either because they aren't familiar enough with technology to do so or they are a temporary user who doesn't have an account. Requiring elevated privileges to access certain content just makes sense. 1 1
renecd 4 Posted September 8, 2025 Posted September 8, 2025 (edited) I'm not sure if this tread is still being followed. It seems the last question back in 2024 is still unanswered....? Anyway, since it seems any requiest for a pincode gets closed and redirected here I will have to try this. So, yes I understand that Emby is very clever and uses multiple users, but on Android/Google/Smart TV you can't just change user easily, you need to reconfigure the server - at least with my setup, using url access rather than the proprietary go-through-emby-central solution, whatever it's called. Besides, it is too easy to forget to logout, and someone might catch a lucky break and access my pron stash. What I really would like. Actually I have to say, demand, is a proper access control to designated libraries such as pron. There already is provisions for not showing any previews or last-seen content from selected libraries, why is it so hard to add a pincode access control? If not possible I'm sorry to say, for all the advantages of Emby, it fails a key requirement and I will have to change to something else. That may be inferior in all other ways, and not my preferred solution after a decade of using Emby, but what can I do. Edited September 8, 2025 by renecd
