MikeyMan 8 Posted October 3, 2014 Posted October 3, 2014 Tried to install it again after a few months, from the server catalog, and the crashes are still there. Any progress on this?
tp546 41 Posted October 3, 2014 Author Posted October 3, 2014 it still crashes for me when i finish something in its entirety but not if i stop before then.
pixsoul 1 Posted October 3, 2014 Posted October 3, 2014 I'm happy to provide logs to someone if required... Although I've not used this pluging since I encountered those issues; if it is still causing it could it not be either fixed or removed from the catalogue?
ebr 16334 Posted October 3, 2014 Posted October 3, 2014 Logs are always needed. And the Windows event log if there is a crash. And step by step exactly what you are doing and what happens. Thx.
scharbag 19 Posted October 5, 2014 Posted October 5, 2014 I am having the same problem with MBC crashing after complete playback. Happened tonight when I tried to navigate to a new item. Attached are the logs from MBC and Win 7 event log in one text file from the time of the crash. Seems to do it when I allow video playback to complete. I am using the latest release versions of both server and client. I also use Shark007 codecs and I use FFMpeg instead of the windows codecs. Computer is an i3 using the built in intel video capabilities. HDMI audio and video to my processor. If I can provide any other useful information, please let me know. Cheers, MBC Crash.txt
Redshirt 1487 Posted October 5, 2014 Posted October 5, 2014 Please provide full logs. A snippet doesn't give a complete picture
scharbag 19 Posted October 5, 2014 Posted October 5, 2014 Here is the complete MBC Log. MBClassic-4102014b90f28ec14ac44ae8fb543215609fc26.log
ebr 16334 Posted October 5, 2014 Posted October 5, 2014 That is not the right MBC log. It is the log after the crash happened. However, the event log is reporting that WMC itself crashed, not us so I would investigate codecs and video drivers. I highly recommend dumping your custom setup and installing LAV. Finally, this specific thread is about a problem that used to exist with the Gamebrowser plug-in (which I think has been solved a long time ago) and you don't even have the game browser plug-in installed so I would suggest a new thread if you identify a MB issue. Thanks.
MikeyMan 8 Posted October 5, 2014 Posted October 5, 2014 Thought this was identified as a trakt plugin issue?
ebr 16334 Posted October 5, 2014 Posted October 5, 2014 Thought this was identified as a trakt plugin issue? Sorry, you are right, I stated the wrong plug-in but he doesn't have that one installed either.
scharbag 19 Posted October 5, 2014 Posted October 5, 2014 K, I will find the right log and post a new thread if needed. Sorry about that. Cheers,
tp546 41 Posted December 15, 2014 Author Posted December 15, 2014 Hi ebr, I know this has been dormant for a while, but I still have this problem I just haven't had time to log on here - if I play anything for more than a couple of minutes and then stop it or get to the end, MBC crashes. Here are my logs: https://dl.dropboxusercontent.com/u/472290/mb3%20logs/MBClassic-15122014de508029854c4bb88f1424afecec56c3.log https://dl.dropboxusercontent.com/u/472290/mb3%20logs/MBClassic-15122014d14974a0e1fb4e6bab16cb8aed5d10c6.log https://dl.dropboxusercontent.com/u/472290/mb3%20logs/event%20log.evtx https://dl.dropboxusercontent.com/u/472290/mb3%20logs/event%20log.xml The event logs are saved in xml and evtx formats - let me know if you need something else or if you want me to start a new thread. Thanks.
tp546 41 Posted December 16, 2014 Author Posted December 16, 2014 You are using the Crystal theme? Yes - is that a known issue with Crystal?
ebr 16334 Posted December 16, 2014 Posted December 16, 2014 Yes, it is and I'm afraid it isn't going to be addressed anytime soon. Those themes have been removed from the catalog until they get more attention from the dev.
MikeyMan 8 Posted February 2, 2015 Posted February 2, 2015 Is that the same status as with chocolate theme? Still not using trakt over here, and would like it back
ebr 16334 Posted February 2, 2015 Posted February 2, 2015 That is a different issue. Trakt is being re-worked. Have you updated?
