jds828 24 Posted March 11, 2016 Posted March 11, 2016 Testing the IPad after the Update.... Scrolling works great now so thanks for that. When I go on live TV and try an HD channel, it goes through the motions and just shows a still image with a play button in the middle which doesn't do anything. SD seems on on the few I tested.
lcasadonte 3 Posted March 30, 2016 Posted March 30, 2016 Did you figure this out. I'm having the same problem. Worked fine previously.
Luke 42243 Posted March 30, 2016 Posted March 30, 2016 Did you figure this out. I'm having the same problem. Worked fine previously. Hi there, sorry to hear this. In order to best help you, please see how to report a media playback issue. Thanks.
