Nathanio 35 Posted March 10, 2016 Posted March 10, 2016 Server Version 3.0.5900.0 EmbyTV App 1.1.60a When I try and start a live TV steam on the AFTV box it spins, starts audio with a blank screen, plays for 2 seconds and then hangs. However, direct plays (beautifully I might add - well done chaps!), so does the Emby mobile app (transcoding) and the web site. I think this a relevant transcoding log. http://172.0.0.1:8096/emby/videos/447acbffd331f25169d1bbfbac23adcb/stream.mkv?DeviceId=b766f59f4bea4355&MediaSourceId=f2261970c5ba4a879105de76466bc63anative&VideoCodec=h264&AudioCodec=aac&AudioStreamIndex=-1&VideoBitrate=39872000&AudioBitrate=128000&PlaySessionId=094befa1d56e439ab8218991218decc6&api_key=e59595069a1143e6a6d5536f28e33307&CopyTimestamps=true {"Protocol":"Http","Id":"f2261970c5ba4a879105de76466bc63anative","Path":"http://172.0.0.231:5004/auto/v55","Type":"Default","Container":"ts","ReadAtNativeFramerate":false,"SupportsTranscoding":true,"SupportsDirectStream":false,"SupportsDirectPlay":true,"RequiresOpening":false,"RequiresClosing":false,"BufferMs":0,"MediaStreams":[{"Codec":"mpeg2video","IsInterlaced":true,"IsDefault":false,"IsForced":false,"Type":"Video","Index":-1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false},{"Codec":"ac3","IsInterlaced":false,"BitRate":192000,"IsDefault":false,"IsForced":false,"Type":"Audio","Index":-1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false}],"PlayableStreamFileNames":[],"Formats":[],"Bitrate":192000,"RequiredHttpHeaders":{}} C:\Users\Administrator\AppData\Roaming\Emby-Server\ffmpeg\20160131\ffmpeg.exe -fflags +genpts -noaccurate_seek -i "http://172.0.0.231:5004/auto/v55" -sn -codec:v:0 libx264 -force_key_frames expr:gte(t,n_forced*5) -vf "yadif=0:-1:0" -pix_fmt yuv420p -preset superfast -crf 23 -b:v 39872000 -maxrate 39872000 -bufsize 79744000 -vsync vfr -map_metadata -1 -threads 0 -codec:a:0 aac -strict experimental -ab 128000 -af "aresample=async=1" -y "S:\Transcode\transcoding-temp\c736e024e2e1d8e68fdc9e34f0ba37c2.mkv" ffmpeg version N-78218-gc86ecdf Copyright (c) 2000-2016 the FFmpeg developers built with gcc 5.3.0 (GCC) configuration: --arch=x86_64 --target-os=mingw32 --cross-prefix=/home/mceuser/ffmpeg-windows-build-helpers/sandbox/cross_compilers/mingw-w64-x86_64/bin/x86_64-w64-mingw32- --pkg-config=pkg-config --disable-w32threads --enable-gpl --enable-libsoxr --enable-fontconfig --enable-libass --enable-libutvideo --enable-libbluray --enable-iconv --enable-libtwolame --extra-cflags=-DLIBTWOLAME_STATIC --enable-libzvbi --enable-libcaca --enable-libmodplug --extra-libs=-lstdc++ --extra-libs=-lpng --enable-libvidstab --enable-libx265 --enable-decklink --extra-libs=-loleaut32 --enable-libx264 --enable-libxvid --enable-libmp3lame --enable-version3 --enable-zlib --enable-librtmp --enable-libvorbis --enable-libtheora --enable-libspeex --enable-libopenjpeg --enable-gnutls --enable-libgsm --enable-libfreetype --enable-libopus --enable-frei0r --enable-filter=frei0r --enable-bzlib --enable-libxavs --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libvo-amrwbenc --enable-libschroedinger --enable-libvpx --enable-libilbc --enable-libwavpack --enable-libwebp --enable-libgme --enable-dxva2 --enable-libdcadec --enable-avisynth --enable-gray --enable-libopenh264 --enable-libmfx --extra-libs=-lpsapi --extra-cflags= --enable-static --disable-shared --prefix=/home/mceuser/ffmpeg-windows-build-helpers/sandbox/cross_compilers/mingw-w64-x86_64/x86_64-w64-mingw32 --enable-runtime-cpudetect libavutil 55. 16.101 / 55. 16.101 libavcodec 57. 24.100 / 57. 24.100 libavformat 57. 23.101 / 57. 23.101 libavdevice 57. 0.101 / 57. 0.101 libavfilter 6. 27.100 / 6. 27.100 libswscale 4. 0.100 / 4. 0.100 libswresample 2. 0.101 / 2. 0.101 libpostproc 54. 0.100 / 54. 0.100 [mpeg2video @ 00000000004de1e0] Invalid frame dimensions 0x0. and another http://172.0.0.1:8096/emby/videos/d45600b1614a0bbe1f8ce6ca19a7d957/stream.mkv?DeviceId=b766f59f4bea4355&MediaSourceId=93b586e2e9a24f6ab6ad742c8a0d8988native&VideoCodec=h264&AudioCodec=aac&AudioStreamIndex=-1&VideoBitrate=39872000&AudioBitrate=128000&PlaySessionId=4f19fdfb3e3d40498fc8fe66c00e89ac&api_key=e59595069a1143e6a6d5536f28e33307&CopyTimestamps=true {"Protocol":"Http","Id":"93b586e2e9a24f6ab6ad742c8a0d8988native","Path":"http://172.0.0.230:5004/auto/v102","Type":"Default","Container":"ts","ReadAtNativeFramerate":false,"SupportsTranscoding":true,"SupportsDirectStream":false,"SupportsDirectPlay":true,"RequiresOpening":false,"RequiresClosing":false,"BufferMs":0,"MediaStreams":[{"Codec":"mpeg2video","IsInterlaced":true,"IsDefault":false,"IsForced":false,"Type":"Video","Index":-1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false},{"Codec":"ac3","IsInterlaced":false,"BitRate":192000,"IsDefault":false,"IsForced":false,"Type":"Audio","Index":-1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false}],"PlayableStreamFileNames":[],"Formats":[],"Bitrate":192000,"RequiredHttpHeaders":{}} C:\Users\Administrator\AppData\Roaming\Emby-Server\ffmpeg\20160131\ffmpeg.exe -fflags +genpts -noaccurate_seek -i "http://172.0.0.230:5004/auto/v102" -sn -codec:v:0 libx264 -force_key_frames expr:gte(t,n_forced*5) -vf "yadif=0:-1:0" -pix_fmt yuv420p -preset superfast -crf 23 -b:v 39872000 -maxrate 39872000 -bufsize 79744000 -vsync vfr -map_metadata -1 -threads 0 -codec:a:0 aac -strict experimental -ab 128000 -af "aresample=async=1" -y "S:\Transcode\transcoding-temp\fe7c45e7908c3f5ec2d39aac93cb2f08.mkv" ffmpeg version N-78218-gc86ecdf Copyright (c) 2000-2016 the FFmpeg developers built with gcc 5.3.0 (GCC) configuration: --arch=x86_64 --target-os=mingw32 --cross-prefix=/home/mceuser/ffmpeg-windows-build-helpers/sandbox/cross_compilers/mingw-w64-x86_64/bin/x86_64-w64-mingw32- --pkg-config=pkg-config --disable-w32threads --enable-gpl --enable-libsoxr --enable-fontconfig --enable-libass --enable-libutvideo --enable-libbluray --enable-iconv --enable-libtwolame --extra-cflags=-DLIBTWOLAME_STATIC --enable-libzvbi --enable-libcaca --enable-libmodplug --extra-libs=-lstdc++ --extra-libs=-lpng --enable-libvidstab --enable-libx265 --enable-decklink --extra-libs=-loleaut32 --enable-libx264 --enable-libxvid --enable-libmp3lame --enable-version3 --enable-zlib --enable-librtmp --enable-libvorbis --enable-libtheora --enable-libspeex --enable-libopenjpeg --enable-gnutls --enable-libgsm --enable-libfreetype --enable-libopus --enable-frei0r --enable-filter=frei0r --enable-bzlib --enable-libxavs --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libvo-amrwbenc --enable-libschroedinger --enable-libvpx --enable-libilbc --enable-libwavpack --enable-libwebp --enable-libgme --enable-dxva2 --enable-libdcadec --enable-avisynth --enable-gray --enable-libopenh264 --enable-libmfx --extra-libs=-lpsapi --extra-cflags= --enable-static --disable-shared --prefix=/home/mceuser/ffmpeg-windows-build-helpers/sandbox/cross_compilers/mingw-w64-x86_64/x86_64-w64-mingw32 --enable-runtime-cpudetect libavutil 55. 16.101 / 55. 16.101 libavcodec 57. 24.100 / 57. 24.100 libavformat 57. 23.101 / 57. 23.101 libavdevice 57. 0.101 / 57. 0.101 libavfilter 6. 27.100 / 6. 27.100 libswscale 4. 0.100 / 4. 0.100 libswresample 2. 0.101 / 2. 0.101 libpostproc 54. 0.100 / 54. 0.100 [h264 @ 00000000003ae2a0] non-existing PPS 0 referenced Last message repeated 1 times [h264 @ 00000000003ae2a0] decode_slice_header error [h264 @ 00000000003ae2a0] no frame! [h264 @ 00000000003ae2a0] non-existing PPS 0 referenced Last message repeated 1 times [h264 @ 00000000003ae2a0] decode_slice_header error [h264 @ 00000000003ae2a0] no frame! [h264 @ 00000000003ae2a0] non-existing PPS 0 referenced Last message repeated 1 times [h264 @ 00000000003ae2a0] decode_slice_header error [h264 @ 00000000003ae2a0] no frame! [h264 @ 00000000003ae2a0] non-existing PPS 0 referenced Last message repeated 1 times [h264 @ 00000000003ae2a0] decode_slice_header error [h264 @ 00000000003ae2a0] no frame! [h264 @ 00000000003ae2a0] non-existing PPS 0 referenced Last message repeated 1 times [h264 @ 00000000003ae2a0] decode_slice_header error [h264 @ 00000000003ae2a0] no frame! [h264 @ 00000000003ae2a0] non-existing PPS 0 referenced Last message repeated 1 times [h264 @ 00000000003ae2a0] decode_slice_header error [h264 @ 00000000003ae2a0] no frame! [h264 @ 00000000003ae2a0] non-existing PPS 0 referenced Last message repeated 1 times [h264 @ 00000000003ae2a0] decode_slice_header error [h264 @ 00000000003ae2a0] no frame! [h264 @ 00000000003ae2a0] non-existing PPS 0 referenced Last message repeated 1 times [h264 @ 00000000003ae2a0] decode_slice_header error [h264 @ 00000000003ae2a0] no frame! [h264 @ 00000000003ae2a0] non-existing PPS 0 referenced Last message repeated 1 times [h264 @ 00000000003ae2a0] decode_slice_header error [h264 @ 00000000003ae2a0] no frame! [h264 @ 00000000003ae2a0] non-existing PPS 0 referenced Last message repeated 1 times [h264 @ 00000000003ae2a0] decode_slice_header error [h264 @ 00000000003ae2a0] no frame! [h264 @ 00000000003ae2a0] non-existing PPS 0 referenced Last message repeated 1 times [h264 @ 00000000003ae2a0] decode_slice_header error [h264 @ 00000000003ae2a0] no frame! [h264 @ 00000000003ae2a0] non-existing PPS 0 referenced Last message repeated 1 times [h264 @ 00000000003ae2a0] decode_slice_header error [h264 @ 00000000003ae2a0] no frame! [h264 @ 00000000003ae2a0] non-existing PPS 0 referenced Last message repeated 1 times [h264 @ 00000000003ae2a0] decode_slice_header error [h264 @ 00000000003ae2a0] no frame! [h264 @ 00000000003ae2a0] non-existing PPS 0 referenced Last message repeated 1 times [h264 @ 00000000003ae2a0] decode_slice_header error [h264 @ 00000000003ae2a0] no frame! [h264 @ 00000000003ae2a0] non-existing PPS 0 referenced Last message repeated 1 times [h264 @ 00000000003ae2a0] decode_slice_header error [h264 @ 00000000003ae2a0] no frame! [h264 @ 00000000003ae2a0] Increasing reorder buffer to 2 [h264 @ 00000000003ae2a0] Increasing reorder buffer to 3 [h264 @ 00000000003ae2a0] mmco: unref short failure
Solution ebr 16336 Posted March 11, 2016 Solution Posted March 11, 2016 Deselect the option in settings to transcode Dolby Digital and see if they work then. 1
Nathanio 35 Posted March 11, 2016 Author Posted March 11, 2016 Deselect the option in settings to transcode Dolby Digital and see if they work then. Thanks ebr!
ebr 16336 Posted March 11, 2016 Posted March 11, 2016 Okay, thanks. That option is gone in .61 because it was more trouble than it was worth. 1
