Raven 6 Posted March 30, 2016 Posted March 30, 2016 I'm now getting the "no remote control" problem after yesterday's update to the apk. Had no issues previously (apart from the random disconnect issue which was easily fixed on an adhoc basis simply by tapping the cast button again).
sh0rty 727 Posted March 30, 2016 Posted March 30, 2016 (edited) in 2.6.29 I can disconnect from CC again, thanks for quick fix. For the no remote problem. It seems to me that it affects just some libraries. E.g. my series libraries are not affected, also my Kids movies. But the other movie library is affected. I cannot believe that you did not have that problem a single time during tests @@Luke. In the current status quo, the Android app is totally useless for me because I just use it for CC streaming. But I'm sure like everytime that you find a solution. Let me know if you need a tester or logs etc. Edited March 30, 2016 by shorty1483
rcocchiararo 1 Posted March 30, 2016 Posted March 30, 2016 It happens on my 4 libraries for me. ps: i mentioned the english language, because i use my phone in spanish, and for a while i thought that using it in spanish was the problem here
Luke 42243 Posted March 30, 2016 Posted March 30, 2016 Let me know if beta 30 improves this. Thanks. 1
sh0rty 727 Posted March 30, 2016 Posted March 30, 2016 Let me know if beta 30 improves this. Thanks.Seems to be fixed in .30 , yay! Well done! Gesendet von meinem HTC One_M8 mit Tapatalk 1
rcocchiararo 1 Posted April 4, 2016 Posted April 4, 2016 I just tried on the latest beta and I could not connect to the Chromecast (button did nothing). For now I have reverted to 2.6.03 and disabled updates. Could you inform me when this fix hits stable? Enviado desde mi Nexus 6P mediante Tapatalk
Luke 42243 Posted April 4, 2016 Posted April 4, 2016 Everything is in stable now. I'm not aware of any issues right now. 1
AndroidVageta 0 Posted April 20, 2016 Posted April 20, 2016 I'm still having this issue. When I start the app everything works fine. Connects to the Chromecast fine, media controls work just fine. When the phone goes into sleep mode though and I turn it back on everything no longer works. Emby shows that I'm disconnected from the Chromecast (gray icon) and the media controls no longer function. Even reconnecting to the Chromecast does nothing. All the while whatever I'm watching continues to play via Chromecast. There never seems to be an actual connection issue with the video. I'm using a LG G2 with Android 4.2.2 (I only use this to stream media). Thoughts?
Luke 42243 Posted April 20, 2016 Posted April 20, 2016 I can't reproduce that but will keep an eye out for it.
AndroidVageta 0 Posted April 20, 2016 Posted April 20, 2016 I can't reproduce that but will keep an eye out for it. Do you know what could be the issue? I find it odd that my phone or others would have this issue that for some reason doesn't affect other people.
