Dysan 2 Posted March 10, 2016 Posted March 10, 2016 When casting from an Android device, the remote controls won't pop up, even when trying to take over the chromecast session on a Browser the remotes wont appear. choosing remote control from the phone doesn't help either. making it impossible to select subtitles or pause the playback attached are the reports, also tested on a Nexus 5 running version 6. 2 screenshots, 18-44-02 when playing, 18-44-11 choosing remote control when playing. Emby server version:3.0.5882.0 Android App version:2.6.09 Chromecast version :2.1.0 Server Log A.txt Server Log B.txt a82c9eae-1333-45b2-b544-ec758687e239.log
Luke 42243 Posted March 17, 2016 Posted March 17, 2016 i have been testing this but unable to reproduce.
Ren34 3 Posted March 18, 2016 Posted March 18, 2016 It happens to me quite a bit too. Unlike your screenshot, when my controls disappear, the chromecast icon goes gray instead of blue. I just click on the cast icon again and select the chromecast already in use. This gives me back my remote controls.
bedollandres 1 Posted March 19, 2016 Posted March 19, 2016 I have the same problem, using latest Stable server and a Chromecast 2. The remote won't show up on the android app. If I use Chrome browser on the same phone I do get access to the controls.
sh0rty 727 Posted March 19, 2016 Posted March 19, 2016 @@Luke could you please upload 2.6.06 here? I remember it's the last version the control showed up correctly. Thanks! Gesendet von meinem HTC One_M8 mit Tapatalk
Luke 42243 Posted March 19, 2016 Posted March 19, 2016 The apk's aren't archived in the play store so i don't have that, sorry. now that we're making apk's available on the website though, you can try the version hosted there. it corresponds with the last non-beta release which was 9 days ago. 1
sh0rty 727 Posted March 19, 2016 Posted March 19, 2016 Unfortunately the website version is 2.6.09. So no benefit. Gesendet von meinem HTC One_M8 mit Tapatalk
rcocchiararo 1 Posted March 19, 2016 Posted March 19, 2016 I am on the same boat here. Initially thought the issue was Android N dev preview, then remembered the update that actually broke it, and even went back to Android 6.0.1. I think I have a copy of the previous APK in a backup I made before trying N, will test later. Enviado desde mi Nexus 6P mediante Tapatalk
rcocchiararo 1 Posted March 19, 2016 Posted March 19, 2016 My backup was of 2.6.03, controls work there. Enviado desde mi Nexus 6P mediante Tapatalk
rcocchiararo 1 Posted March 21, 2016 Posted March 21, 2016 i have been testing this but unable to reproduce. Any luck on this? As i said, 2.6.03 worked fine, but since Android N preview was not the issue, i went back to it, and 2.6.03 does not open there (2.6.10 does, but has no remote controls )
rcocchiararo 1 Posted March 21, 2016 Posted March 21, 2016 Ok Hope the fact that 2.6.03 had no suck issue might shine some light on this matter. Will have to find some workarround meanwhile (pc from another room, or wife's iphone?). Emby keeps rocking on my chromecast, and the SAME frekaing media triggers transcoding on plex (still not able to make the full jump)
Luke 42243 Posted March 22, 2016 Posted March 22, 2016 Keep in mind mobile chrome supports chromecast now, as a temporary workaround until this is resolved. If you can come up with more specific steps to reproduce then that will make things easier to narrow down.
sh0rty 727 Posted March 22, 2016 Posted March 22, 2016 (edited) Keep in mind mobile chrome supports chromecast now, as a temporary workaround until this is resolved. If you can come up with more specific steps to reproduce then that will make things easier to narrow down. Currently using exact this Plan B. Exporting Emby Webpage as direct link/app in Android Chrome works actually pretty flawlessly except the lack of libvlc. Currently using latest Dev Server, and latest Android App. Reproducation steps are pretty simple for everyone affected: 1. Open Emby app 2. Connect to CC -> Successful 3. Navigate around through movies/series -> correct page/summary is shown on TV 4. Start a stream -> stream starts but neither the control bar shows in app, nor is something displayed in Remote control section 5. Due to fact 4., the stream needs to be aborted by disconnecting CC using the CC button in app This happens on nearly every movie (direct stream or transcoding), but somehow most of my series are not affected. Edited March 22, 2016 by shorty1483 1
jamvids 39 Posted March 22, 2016 Posted March 22, 2016 I have been having issues with the remote as well, mainly with music. I can start an album / playlist (to CCA) and the remote will be there but skip a song and it randomly disappears. Sometimes it stays in the notification bar and sometimes not. It seems song related as if I manually play the next item in the list the remote returns but if I put the offending song back on the remote never happens. It happens on my Sony devices and galaxy tab. I can re-create the problem and post logs if needed. Direct play works fine. Hope this helps. Sent from my E6853 using Tapatalk
rcocchiararo 1 Posted March 22, 2016 Posted March 22, 2016 The steps to reproduce for me are simply: 1) Connect to chromecast 2) Hit play 3) Control bar/notification never appears, can only stop by disconecting from chromecast I did not try with movies, series have the issue for me.
optimalt 10 Posted March 26, 2016 Posted March 26, 2016 The steps to reproduce for me are simply: 1) Connect to chromecast 2) Hit play 3) Control bar/notification never appears, can only stop by disconecting from chromecast I did not try with movies, series have the issue for me. Yeah, this applies to me and my users to. Did just realize I can disconnet the chromecast in the Chromecast app. I told my users that they had to unplugg their Chromecasts to stop a movie.. [emoji16] Skickat från min SM-G920F via Tapatalk
rcocchiararo 1 Posted March 27, 2016 Posted March 27, 2016 The beta versión of emby for android does not present this issue. Enviado desde mi Nexus 6P mediante Tapatalk
rcocchiararo 1 Posted March 28, 2016 Posted March 28, 2016 false alarm, it went away. either it happens on some series, or having the phone in english was what actually fixed it. will experiment further today.
sh0rty 727 Posted March 28, 2016 Posted March 28, 2016 (edited) In latest beta, I am not even able to stop screen by disconnecting CC. The popup menu for disconnect simply does not react. But it simply never occurs in some libraries while it never happens in others. Gesendet von meinem HTC One_M8 mit Tapatalk Edited March 28, 2016 by shorty1483
Luke 42243 Posted March 28, 2016 Posted March 28, 2016 In latest beta, I am not even able to stop screen by disconnecting CC. The popup menu for disconnect simply does not react. But it simply never occurs in some libraries while it never happens in others. Gesendet von meinem HTC One_M8 mit Tapatalk Thanks, This I see and can resolve.
rcocchiararo 1 Posted March 28, 2016 Posted March 28, 2016 True, the beta I tried yesterday not only did not show the control bar, disconnecting was not working either. Sent from my Nexus 6P using Tapatalk
rcocchiararo 1 Posted March 29, 2016 Posted March 29, 2016 Just tried the last second beta. Disconnect button fixed. Remote control missing in all my libraries (TV, anime and movies), and my device is now in English. Sent from my Nexus 6P using Tapatalk
