dubs 1 Posted March 8, 2016 Posted March 8, 2016 Not sure if this is the correct place to report this, but just had a slightly frustrating issue (amplified by the fact initially I thought it related to the current "update" issue where it is showing an update is available that doesn't exist, but nevermind ). I've been running the server running on a separate port, changing the "Local http port number" under Advanced, Hosting settings. All fine. Today i was flicking through the settings, decided to update the other ports to all be the same port: Local http port number Public http port number Local https port number Public https port number In hindsight, this was a mistake, even in standard web applications http and https do not run on the same port. What followed was frustrating. Starting the service reported a success. Running a service emby-server status reported everything was fine. Only some further digging revealed the issue: - The PID changed every time I ran service emby-server status - Looking in /var/log/syslog showed: Mar 8 22:09:05 emby kernel: [ 999.749357] init: emby-server main process ended, respawning Mar 8 22:09:05 emby /proc/self/fd/9: DEBUG: IFS=' #011#012'#012OPTIND='1'#012PATH='/usr/local/sbin:/usr/local/bin:/usr/bin:/usr/sbin:/sbin:/bin'#012PPID='1'#012PS1='# '#012PS2='> '#012PS4='+ '#012PWD='/'#012TERM='linux'#012UPSTART_INSTANCE=''#012UPSTART_JOB='emby-server' Mar 8 22:09:08 emby kernel: [ 1002.875188] init: emby-server main process ended, respawning Mar 8 22:09:08 emby /proc/self/fd/9: DEBUG: IFS=' #011#012'#012OPTIND='1'#012PATH='/usr/local/sbin:/usr/local/bin:/usr/bin:/usr/sbin:/sbin:/bin'#012PPID='1'#012PS1='# '#012PS2='> '#012PS4='+ '#012PWD='/'#012TERM='linux'#012UPSTART_INSTANCE=''#012UPSTART_JOB='emby-server' Finally, on a whim I looked in /var/lib/emby-server and found the logs folder and saw it spewing "server-#######.txt" files and "unhandled_##############,txt" files. The unhandled ones contained: InnerException: System.Net.HttpListenerException Prefix already in use. This pointing me to the issue. Now, the point of this post is 2 fold. 1. The fix - Edit /var/lib/emby-server/config/system.xml so the PublicPort, PublicHttpPort, HttpServerPortNumber, HttpsPortNumber are all different. I expect some can be the same, but this was the quickest option I set HttpServerPortNumber to be the standard port all my media PCs and such use. 2. A request - Since clearly this is an easy way to break the server, could some additional checking be added to the page? Detect for a conflict and report an error rather than save the changes. Apologies for the rather long winded post, but I tend to ramble when trying to be detailed dubs
Luke 42243 Posted March 9, 2016 Posted March 9, 2016 Hi, yes we should add some checks to prevent you from being able to do that. Thanks. 1
