A8HTPC 38 Posted December 22, 2013 Posted December 22, 2013 Hard to explain, but it seems the screen saver is opening in a separate window instead of within MBT. I have been minimizing MBT a lot to work on my HTPC, though if I keep it minimized and the pc is idle for a long time the screen saver pops up in a very tiny window pictured below. Sometimes this window is located at the very bottom of the screen, more toward the left. I can't click on it and if I bring up MBT from the taskbar, I can't click on anything or move within MBT, I have to go to the task bar and bring up the screen saver window which then locates to the top left of the screen. I have to move the mouse a lot to make it go away and then I have access to MBT. Screen saver in tiny little window. I can't click on it, I have to move to the task bar to click on it and its located in the MBT window group After click on the screen saver from the taskbar in the MBT icon group, and clicking on MBT, below is what is presented. 1
jibenito 3 Posted December 23, 2013 Posted December 23, 2013 +1 and when I maximice MBT, the remote controller doesn't run ok because the focus of the window is in the small screensaver window...
hhb97b 11 Posted December 23, 2013 Posted December 23, 2013 I'm also seen this. However I have to play a video before the issue sets in.
jj12345 25 Posted December 23, 2013 Posted December 23, 2013 Maybe that explains why sometimes (not always) my remote control won't turn of the screen saver... i have to actually grab a mouse and move it to get the screen saver to go away.
