denz 501 Posted March 7, 2016 Posted March 7, 2016 I would like to know how long does it take usually to generate a thumbnail I have recordings that have been sitting over 7 days without thumbnail is there something that is causing it to take so long ? WMC creates a thumbnail almost immediately. Is there a setting that I may have accidently changed for thumbnails not to be generated. Thanks
Luke 42186 Posted March 7, 2016 Posted March 7, 2016 should be almost immediate. but once in a while ffmpeg will fail to generate images for some files.
denz 501 Posted March 8, 2016 Author Posted March 8, 2016 Thanks Luke. I will do more testing so it must be something specific to Australian recordings. I will keep an eye on the logs so hopefully the logs show something so that is can be fixed.
Solution denz 501 Posted March 14, 2016 Author Solution Posted March 14, 2016 I found why it didn't generate thumbnails not sure why but it if it helps others in serverwmc there is a http tab and there is a tick box use URL instead of SMB/UNC paths for Recorded TV if that is disabled all the thumbnails are generated.
