rcarteraz 12 Posted March 6, 2016 Posted March 6, 2016 I'm trying to setup ET for my brother so he can access my server. He's a user on my server with his emby connect account linked. Now whenever we go to login after verify with pin it just goes back to the screen to select server instead of selecting a user and proceeding. When you select a server or emby connect it goes back to he pin verification. It does this even when I use my emby connect Id. How can I fix this?
Luke 42241 Posted March 6, 2016 Posted March 6, 2016 I'll have to look at it but it's probably failing to connect and then instead of showing an error message just bouncing you around.
rcarteraz 12 Posted March 6, 2016 Author Posted March 6, 2016 (edited) I'll have to look at it but it's probably failing to connect and then instead of showing an error message just bouncing you around. Thanks for the response and looking in to it. I tried at another location with Chrome and I have the same result. Interestingly, on my iPhone I'm able to with Chrome but I have a feeling that's because my initial try was while connected to the LAN the emby server is on. I just tried with Safari on my iPhone (offsite) and it's the same result, just back to the server selection loop. embyserverlog.txt Edited March 6, 2016 by rcarteraz
goidudu 0 Posted March 7, 2016 Posted March 7, 2016 Hi admin, I am new to this. My e mail is thai-tran@sbcglobal.net. Please send me the inviation for Luke server so I can try it out. The link you sent me I did not know and now it is expired already. I will join the premium membership after that,.T hanks a lot
rcarteraz 12 Posted March 13, 2016 Author Posted March 13, 2016 I'll have to look at it but it's probably failing to connect and then instead of showing an error message just bouncing you around. Any update to this? Thank you.
Luke 42241 Posted March 13, 2016 Posted March 13, 2016 i haven't been able to reproduce it. No problem found. If he's using the web version, make sure he's using the http url if your emby server is not setup for https yet.
rcarteraz 12 Posted March 13, 2016 Author Posted March 13, 2016 i haven't been able to reproduce it. No problem found. If he's using the web version, make sure he's using the http url if your emby server is not setup for https yet. Thanks for the reply. Tried both web version (via http) and the actual windows app itself. Same issue with both however ,no issues connecting via the non-theater web browser version; just with Emby Theater. Seeing as they're using a laptop connected to a television, Emby Theater would be best for the remote support. I'll have him uninstall/reinstall as well as clear cache and cookies for the browser and see if that helps at all.
