Pirlo1966 22 Posted March 9, 2016 Posted March 9, 2016 Burned in means that, since the subtitle information is actually graphical instead of text, they need to be super-imposed on the video by the server. Many BD discs contain these types of graphical subs but it just depends. Right. As far as I've seen all BD in Europe have pgssubs. Does this means direct play is out of the emby equation in future?
Luke 42244 Posted March 9, 2016 Posted March 9, 2016 the video player framework we're using for android is developing rapidly, so i wouldn't say permanently, but certainly right now. A great option is to use the open subtitle downloader to obtain text versions of your subtitles, this way you get the best of both worlds. You can use pgs on clients that can handle it natively, the others can use text.
ebr 16337 Posted March 9, 2016 Author Posted March 9, 2016 My shield tv as version 1.1.59g Expired.When will i receive latest beta. thanks There is a new beta up today. However, the betas do not extend the trial period for the app.
Daimon 6 Posted March 9, 2016 Posted March 9, 2016 I have some mkv files that have two audio tracks, one DD 5.1 and one stereo AAC. DD 5.1 is set as default track. When playing those files I only get stereo sound. When I check the audio track option none of the tracks is selected. Trying to select DD 5.1 track nothing happens. Selecting the stereo track first then the DD 5.1 track I get transcoding and pcm mulitchannel. Playing mkv files with only one track, DD 5.1 get's passed trough to the receiver. This is on an Nvidia Shield. version 1.1.60g
ebr 16337 Posted March 10, 2016 Author Posted March 10, 2016 I have some mkv files that have two audio tracks, one DD 5.1 and one stereo AAC. DD 5.1 is set as default track. When playing those files I only get stereo sound. What are your audio preference settings in your user playback settings area?
mmb 5 Posted March 10, 2016 Posted March 10, 2016 Hey ebr, are you working on the audio issues on the Sony TVs (no PCM-Multichannel)? I asked the Sony Support about that problem, but they can't give me an answer, if PCM Multichannel would ever include in those TV's. So i would be very happy if you could serve DTS transcode to AC-3 on the Sony TV's. Please tell me, if you could imagine to add this feature.
Daimon 6 Posted March 10, 2016 Posted March 10, 2016 What are your audio preference settings in your user playback settings area?
ebr 16337 Posted March 11, 2016 Author Posted March 11, 2016 I have some mkv files that have two audio tracks, one DD 5.1 and one stereo AAC. DD 5.1 is set as default track. When playing those files I only get stereo sound. When I check the audio track option none of the tracks is selected. Trying to select DD 5.1 track nothing happens. Selecting the stereo track first then the DD 5.1 track I get transcoding and pcm mulitchannel. Playing mkv files with only one track, DD 5.1 get's passed trough to the receiver. This is on an Nvidia Shield. version 1.1.60g Which track is listed first?
ebr 16337 Posted March 11, 2016 Author Posted March 11, 2016 Wow, it is even in front of the video track. I wonder if that might be the problem. Is it possible for you to re-order one of those and see if it makes a difference? Maybe the player is looking for the first track after the video stream.
Daimon 6 Posted March 11, 2016 Posted March 11, 2016 That fixed it. But it still doesn't show what track is selected in the player. I also have som mkv files with flac audio track and 5.1 plays without transcoding but 7.1 gets transcoded. The shield is connected to a 7.1 receiver.
ebr 16337 Posted March 11, 2016 Author Posted March 11, 2016 Luke - I have max channels set to 8 in my profile. Is that being overridden somewhere else down the line? Daimon - can you post the transcoding log from when that 7.1 item transcoded?
Daimon 6 Posted March 11, 2016 Posted March 11, 2016 After checking the logs it looks like it's the PGSSUB subtitle track that triggers the transcoding. Found an 7.1 movie whitout that track and it direct played. But I don't get any sound on files with 5.1 and 7.1 flac anymore.
ebr 16337 Posted March 11, 2016 Author Posted March 11, 2016 Hang on, before you said 5.1 FLAC was playing fine...
Daimon 6 Posted March 11, 2016 Posted March 11, 2016 yeah sorry, I was a little to quick when I tested now I just started the file to see that it direct played and stopped it again. When I found a 7.1 flac that direct played and didn't get any sound I went back and tested 5.1 just to find no sound on those also.
ebr 16337 Posted March 11, 2016 Author Posted March 11, 2016 Can you please play one of those and then use the "Send Log" feature?
Daimon 6 Posted March 11, 2016 Posted March 11, 2016 sent two logs, one after playing 5.1 flac and the other with 7.1 flac
ebr 16337 Posted March 11, 2016 Author Posted March 11, 2016 Okay, thanks. Looks like the player doesn't support flac audio so I'll have to remove it.
mmb 5 Posted March 12, 2016 Posted March 12, 2016 @ebr: what's the reason, that you don't give me a clear answer to my question? Plex (on Android TV) is able to do transcode DTS to Dolby, Emby Server is able to do that on Chromecast streaming too. So why not Emby on (Sony) Android TV?Even if you say "no, that's not possible", please let me know it. I own this Sony TV now for 6 months, Emby Android was the main reason to buy this TV and i still like this App very much (really much more than Plex or Kodi), but i can't use it without DTS support.
ebr 16337 Posted March 12, 2016 Author Posted March 12, 2016 @ebr: what's the reason, that you don't give me a clear answer to my question? Plex (on Android TV) is able to do transcode DTS to Dolby, Emby Server is able to do that on Chromecast streaming too. So why not Emby on (Sony) Android TV?Even if you say "no, that's not possible", please let me know it. I own this Sony TV now for 6 months, Emby Android was the main reason to buy this TV and i still like this App very much (really much more than Plex or Kodi), but i can't use it without DTS support. I have tried doing that but it is far from reliable and I hate to add yet another option but that may be the way it has to go. Oh, wait - your ATV is on Android 5.1 isn't it? That would be another complication.
mmb 5 Posted March 12, 2016 Posted March 12, 2016 (edited) Okay, i think i understand, thanks for your answer. But which another complication? Edited March 12, 2016 by mmb
mmb 5 Posted March 12, 2016 Posted March 12, 2016 Yes it is 5.1(.1). Please let me know, if there is something i can test on my TV...
mmb 5 Posted March 12, 2016 Posted March 12, 2016 I think the main complication of this TV's is Sony :-) There is no area, which is working 100% correct and i don't think that Marshmallow will help at many of those problems
Redshirt 1487 Posted March 12, 2016 Posted March 12, 2016 Okay, thanks. Looks like the player doesn't support flac audio so I'll have to remove it. Flac support, inside webm/mkv, was added a few weeks ago but it's still in the dev branch. Hopefully in the next month or so it'll make it to release.
kefler 8 Posted March 13, 2016 Posted March 13, 2016 (edited) On what platform, playing with what kind of content, direct streaming or transcoding...? EBR -- Sorry I have been on the road and just got home. This weird skip forward/back issue is 100% repeatable for me on every media file in my library. It's transcoding, i'm using the software player (not VLC). Basically if you use the navigation controls to skip forward/back, as soon as you stop skipping and it begins playing the progress resets to 0. And yes, even if I resume a show, say it's at 25:32, it starts at the right point but the timer is at 0. I just realized this is why none of the shows I have ever show as complete.. because it's rare that I watch the show all the way through w/o skipping. Edit: still occurs on .61 Edited March 13, 2016 by kefler
