steve1977 67 Posted December 22, 2013 Posted December 22, 2013 Really like the people section. Just tried to filter for "actors only". Unfortunately, this does not appear to work well as Spielberg remains the #1 actor of my collection, which obviously is incorrect. Probably caused by "Executive Producer" being perceived as an actor name? Same for composers et al. Any chance to look into and fix this bug? Thanks!
Luke 42206 Posted December 22, 2013 Posted December 22, 2013 there's nothing to fix. sometimes the data from the providers is incomplete or incorrect
steve1977 67 Posted December 22, 2013 Author Posted December 22, 2013 Thanks for your reply. Not 100% sure whether this is indeed a provider issue. I looked "Gremlins" up on TMDB, which it appears to be provided from? https://www.themoviedb.org/movie/927-gremlins/cast You will see from the list that Spielberg is credited at co-producer and not as crew (i.e., not as actor). Unless the provider is different from TMDB, it should not be a provide issue?
Luke 42206 Posted December 22, 2013 Posted December 22, 2013 i'll leave you to dig into your metadata to find it
Luke 42206 Posted December 7, 2020 Posted December 7, 2020 @steve1977 Support for composers is coming in Emby Server 4.6:
