Teddy 100 Posted March 5, 2016 Posted March 5, 2016 I'm using Version 3.0.5896.0 and have a directory with several home movies, not the file "xxxxxx-poster.jpg" for each film is created, only the .nfo file.It has disappeared this functionality with the latest versions of Emby Server?
Solution Luke 42186 Posted March 5, 2016 Solution Posted March 5, 2016 No, it hasn't. Make sure image extraction is enabled under metadata -> services. 1
Teddy 100 Posted March 5, 2016 Author Posted March 5, 2016 Luke the problem is solved . It was enabled Fetch primary in the section for "Home videos" but disabled fetch forĀ primary "Movies" section. Emby Server believed that detect the difference between movies and home movies. Thanks a lot to support
