arsim 1 Posted March 5, 2016 Posted March 5, 2016 @@babgvant I have found an issue in the v2.0 emby theater where Anamorphic DVDs converted to mkv format are not displayed properly. Emby seems to follow the video pixel width parameter (720) in the mkv header, but not the display width parameter (853). This results in the video being player back in 4:3 (720x480) instead of 1.78 ratio (853x480). All other players seem to follow the display width including Emby server. Has anyone else had this issue?
Walter 10 Posted March 5, 2016 Posted March 5, 2016 http://emby.media/community/index.php?/topic/32078-problems-with-720p-and-lower-resolution/&do=findComment&comment=307555
babgvant 143 Posted March 5, 2016 Posted March 5, 2016 @@babgvant I have found an issue in the v2.0 emby theater where Anamorphic DVDs converted to mkv format are not displayed properly. Emby seems to follow the video pixel width parameter (720) in the mkv header, but not the display width parameter (853). This results in the video being player back in 4:3 (720x480) instead of 1.78 ratio (853x480). All other players seem to follow the display width including Emby server. Has anyone else had this issue? Could I get a sample file? Does it reproduce w/ madVR & EVR+?
Walter 10 Posted March 6, 2016 Posted March 6, 2016 @babgvant Its only in MadVR, here is a sample file. 50 First Dates (2004).7z
babgvant 143 Posted March 6, 2016 Posted March 6, 2016 @babgvant Its only in MadVR, here is a sample file. So just to be clear. It works as expected with EVR+, but not madVR?
Walter 10 Posted March 6, 2016 Posted March 6, 2016 Yeah, only problem is in MadVR. If you use an older version of MadVR it works fine. I think it's related to the new zoom feature they added. I posted screen shots in this post http://emby.media/community/index.php?/topic/32078-problems-with-720p-and-lower-resolution/&do=findComment&comment=307555.
Harblar 29 Posted March 7, 2016 Posted March 7, 2016 I'm having the same issue. Seems as though this happened in the past, as well, on the old Emby Theater.
babgvant 143 Posted March 7, 2016 Posted March 7, 2016 Yeah, only problem is in MadVR. If you use an older version of MadVR it works fine. I think it's related to the new zoom feature they added. I posted screen shots in this post http://emby.media/community/index.php?/topic/32078-problems-with-720p-and-lower-resolution/&do=findComment&comment=307555. If you replace the version of madVR included w/ Emby with the latest on Doom9, does it still reproduce? LMK if you need assistance with that process.
Walter 10 Posted March 7, 2016 Posted March 7, 2016 (edited) Yeah the latest version (0.90.15) still has the issue. I have (0.88.21) installed and that does not produce the stretched screen. That was the last version to not include the Zoom feature and black bar removal. Edited March 7, 2016 by Walter
babgvant 143 Posted March 7, 2016 Posted March 7, 2016 Have you raised the issue on the madVR thread at Doom9?
gcoupe 63 Posted March 7, 2016 Posted March 7, 2016 Yep, I'm seeing this issue as well: http://emby.media/community/index.php?/topic/29774-new-version-testing/page-47&do=findComment&comment=309331
Walter 10 Posted March 7, 2016 Posted March 7, 2016 (edited) No, cause it only happens with MBTheater. MPC does not exhibit this issue. So I was thinking it was an issue with the player in Theater. I would just use EVR+ but as you can see in this screenshot it looks awful compared to MadVR. http://www.screenshotcomparison.com/comparison/164734 Edited March 7, 2016 by Walter
babgvant 143 Posted March 7, 2016 Posted March 7, 2016 That's odd. Wonder why it would only reproduce in ET. What GPU are you using? Can you confirm the version of EVR+ (right click on the dll and look at the properties tab).
Walter 10 Posted March 7, 2016 Posted March 7, 2016 (edited) 1.0.0.7, Nvidia GTX 970. But it does it all on my computers Intel, ATI and Nvidia. Did the file I send you play fine on your copy of ET? It was ripped with MakeMKV then converted in handbrake. I don't have any codecs installed the only players I use are ET and the MPC-HC to watch DVDs. I just wonder if something is broken on my end, EVR+ should not look so pixelated. I have tried everything I know, clean install, remove everything, etc. And its only broken for DVD content. 720p and 1080p work just fine. Edited March 7, 2016 by Walter
babgvant 143 Posted March 7, 2016 Posted March 7, 2016 1.0.0.7, Nvidia GTX 970. But it does it all on my computers Intel, ATI and Nvidia. Did the file I send you play fine on your copy of ET? It was ripped with MakeMKV then converted in handbrake. I don't have any codecs installed the only players I use are ET and the MPC-HC to watch DVDs. I just wonder if something is broken on my end, EVR+ should not look so pixelated. I have tried everything I know, clean install, remove everything, etc. And its only broken for DVD content. 720p and 1080p work just fine. madVR will make a big difference on non-Intel HW, but it is curious that EVR+ looks that bad. I just changed the way it works so that's surprising. Although it's possible that GPU scaling for this type of content isn't great. I haven't had a chance to look at the file yet.
elshagon 44 Posted March 9, 2016 Posted March 9, 2016 Not sure if this is related, but tonight I noticed a DVD converted to MKV play in 4x3 when it should have been 16x9 as well. One odd thing is when I hit my mouse to take it out of full screen mode the video switched to 16x9 and stayed there. I backed out and tried it again. Once again the movie started in 4x3 and reverted to 16x9 once taken out of full screen. You can then go back to full screen and retain the 16x9.
Harblar 29 Posted March 9, 2016 Posted March 9, 2016 Hitting the restore Icon twice (in the upper right corner) fixes the issue. Obviously a quirk somewhere, but I don't have a clue where or how to fix it.
babgvant 143 Posted March 16, 2016 Posted March 16, 2016 Yeah, only problem is in MadVR. If you use an older version of MadVR it works fine. I think it's related to the new zoom feature they added. I posted screen shots in this post http://emby.media/community/index.php?/topic/32078-problems-with-720p-and-lower-resolution/&do=findComment&comment=307555. Should be fixed. Hopefully @@Luke will have a chance to pull in soon. 1
Guest asrequested Posted March 17, 2016 Posted March 17, 2016 (edited) Sorry guys, but it still happens in 2.0.7, only with EVR+, although, the aspect ratio does appear to be correct... Here's a link to the file, babgvant, if you want to test. I have an i7 6700k with an intel HD530 GPU and running Win 10 pro. https://drive.google.com/file/d/0B00tLdPCXhgCM3d4RnRKTFNPSEU/view?usp=sharing Edited March 17, 2016 by Doofus
arsim 1 Posted March 17, 2016 Author Posted March 17, 2016 Thanks guys, fixed on 2.0.7 with MadVR Theatrer is coming along nicely, seem to be using it more than Kodi now.
babgvant 143 Posted March 17, 2016 Posted March 17, 2016 Sorry guys, but it still happens in 2.0.7, only with EVR+, although, the aspect ratio does appear to be correct... Here's a link to the file, babgvant, if you want to test. I have an i7 6700k with an intel HD530 GPU and running Win 10 pro. https://drive.google.com/file/d/0B00tLdPCXhgCM3d4RnRKTFNPSEU/view?usp=sharing Thanks. I'll have a look. Pretty sure this is a different issue though, just targeting an issue with madVR before.
babgvant 143 Posted March 17, 2016 Posted March 17, 2016 Thanks. I'll have a look. Pretty sure this is a different issue though, just targeting an issue with madVR before. If you replace Emby.Theater.DirectShow.dll with this one, is there a change?
Luke 42243 Posted March 17, 2016 Posted March 17, 2016 I think when we update the com objects inside the app they are not necessarily extracted on the next run. as a test, try a fresh new install of the app and see if it behaves any differently than above.
Guest asrequested Posted March 18, 2016 Posted March 18, 2016 (edited) I think when we update the com objects inside the app they are not necessarily extracted on the next run. as a test, try a fresh new install of the app and see if it behaves any differently than above. When I update, I download and install over the top. I'll try babgvant's idea first, and if it doesn't work, I'l remove theater completely and reinstall EDIT: Neither solution worked Edited March 18, 2016 by Doofus
