One channel guide data not showing
I saw another thread with a similar symptom but didn't seem to be the same issue.  I think I see where the problem is but not sure where to go to resolve.
2016/02/27 21:52:50.878 Received client request: MediaBrowser^@PERKINS-HP@|::1|GetEntries|44712|1456635170|1456894370
2016/02/27 21:52:50.878 warning: no entries found for channel: Drama, startTime: 2/28/2016 4:52:50 AM, endTime: 3/2/2016 4:52:50 AM, currentTime:  2/28/2016 5:52:50 AM
2016/02/27 21:52:50.878 GetEntries> Channel: Drama/502, EPG entries: 0
2016/02/27 21:52:50.879 Finished request GetEntries in 0.00s
2016/02/27 21:52:50.879 Received client request: MediaBrowser^@PERKINS-HP@|::1|GetEntries|44713|1456635170|1456894370
2016/02/27 21:52:50.896 GetEntries> Channel: KNBCHD/504, EPG entries: 79
2016/02/27 21:52:50.896 Finished request GetEntries in 0.02s
In WMC and Emby the channel name is KCBSHD/502, so I can't see where ServerWMC is getting "Drama/502"...  Is there a config somewhere where I can change the name of the channel so ServerWMC picks it up correctly?
Perx
krustyreturns
In wmc, edit your channel list.  Go down to this 502 channel and you'll see an internet channel called 'Drama' with the same number.  Disable it, and save the channels.  Then restart serverwmc.
Ugh, how embarrassing, I thought I had looked everywhere, that did it.  I went to Settings > TV > Guide > Edit Channels, and yes saw two channels for 502 including the Internet Channel "Drama".  Disabled that one and all good.
Thanks!
  • Like 1
