BigGoose62 72 Posted March 4, 2016 Posted March 4, 2016 Can anyone that has played around with the new Theater tell me if there is support for dynamic range compression? I want to be able to keep the explosion volume down and the dialogue volume up, which is easy to do In VLC. Thanks!
Solution Luke 42241 Posted March 4, 2016 Solution Posted March 4, 2016 The windows app has a setting for this,yes. 1
BigGoose62 72 Posted March 4, 2016 Author Posted March 4, 2016 Awesome, thanks! I need to revisit Theater
