ravenj 2 Posted March 3, 2016 Posted March 3, 2016 Hello, I normally use the web client (firefox) mainly to listen to music from my server. Since yesterday's first update (using beta) flac music stops after 4-5 songs and, after that, I can't listen to one music straight. This happens both in firefox and Chrome. Before yesterday I had no problems. Also theater plays normally, although I don't like using it because it takes forever to change track. Also, only using Firefox, when I try to play any movie I get an error. It's ok with chrome. Also tried different computer with firefox and the problem is the same. Thank you in advance for your help. Best regards Log_server_flac.txt Log_server_mkv.txt Log_transcoding_flac.txt Log_transcoding_mkv.txt
Luke 42241 Posted March 4, 2016 Posted March 4, 2016 Sorry for not responding but after seeing your post yesterday i tested with firefox and played music for over an hour straight with no problems. i don't know what to say, those logs all look fine to me.
ravenj 2 Posted March 7, 2016 Author Posted March 7, 2016 (edited) Hi, I've been trying to replicate the problem and it only happens when I play a specific music. After playing it I can't play any other flac file until I reboot my server. I believe it's a file problem and I will replace it. I think the mystery is solved. Still can't find the problem with MKV. Thank you. Edited March 7, 2016 by ravenj
Luke 42241 Posted March 7, 2016 Posted March 7, 2016 if you can provide a copy of the file, i can't make it play if it's a bad file but i can fix the reboot requirement. thanks.
Pimmetje 0 Posted March 28, 2016 Posted March 28, 2016 I have a issue with FLAC files on the emby webclient after latest update firefox see this ticket: https://bugzilla.mozilla.org/show_bug.cgi?id=1258802
Luke 42241 Posted March 28, 2016 Posted March 28, 2016 Thanks for taking the initiative. Just fyi, on firefox 46 beta i can play flac no problem via server transcoding.
