Oleg 15 Posted March 3, 2016 Posted March 3, 2016 Hello. I'll tell you the whole version. Was 3.0.5818.0 version of the server, updated to 5870. A D series of DLNA to work applet version 1.0.6 or 2.1.3 do not work. On the N series works applet 2.1.3, but does not work DLNA. The 5870 updated job DLNA ... roll back to version 5818. On the H series works DLNA and Applet 2.1.3, on the D series only works DLNA, the applet does not start, the TV hang on a minute, and reloads. Via the web to all the D series works. Logs attached(in all zip or separately). Best Regards Oleg logs.zip server-63592559233.txt server-63592560000.txt transcode-98d3b075-e6b9-4206-824b-08efa6fc8d92.txt
FrostByte 5453 Posted March 3, 2016 Posted March 3, 2016 (edited) On the D-series TV using v1.0.6 does the installation actually finish and you get a message that it's complete? After clicking the Emby icon to start the app do you see the splash screen with the picture of the TV? Edit: As far as your DLNA issue I believe there were some fixes with Samsung DLNA in beta server releases recently. Hopefully those help your DLNA issue, but I don't believe those would effect this app any Edited March 3, 2016 by FrostByte
Oleg 15 Posted March 3, 2016 Author Posted March 3, 2016 By clicking on the icon, a black screen, no image, and then restart the TV.
Oleg 15 Posted March 3, 2016 Author Posted March 3, 2016 I have Asustor 5104T ... I forgot to say more. It has been updated from version 3.10 MONO to 4.2
FrostByte 5453 Posted March 3, 2016 Posted March 3, 2016 I just loaded 1.0.6 on my F6500 and it is running okay. Could you try deleting the app, then reloading. Make sure it says "Update Complete" and then restart. The first screen you see should be the IP screen again
Solution Oleg 15 Posted March 4, 2016 Author Solution Posted March 4, 2016 Hello. Everything worked. Thank you so much.Apparently the problem was with me.Once again, thank you very much. 2
