Nathanio 35 Posted March 2, 2016 Posted March 2, 2016 I've had a couple of failures on records recently where the show appears to have recorded but not transcoded correctly. I notice that I don't get any chapter previews and that under media info I get level -99 instead of 41 on successful ones. Video CodecH264Codec tagavc1Level-99Resolution544x576Aspect ratio16:9AnamorphicNoInterlacedNoFramerate25Bitrate1485 kbpsRef frames1 Audio LanguageundCodecAACCodec tagmp4aProfileLCLayoutstereoChannels2 chBitrate267 kbpsSample rate48000 khzDefaultYes Containermp4 Path\\slinky\EmbyTV\Series\Robson Green Extreme Fisherman\Robson Green Extreme Fisherman S01E06 Borneo.mp4 Playing in VLC gives a blank video window. Please see two transcode failure log files attached CallTheMidwife_failure.txt Robson failure.txt CallTheMidwife_failure.txt Robson failure.txt
Luke 42241 Posted March 2, 2016 Posted March 2, 2016 If you'd like, try the beta server and see if that reacts differently. thanks. 1
Nathanio 35 Posted March 2, 2016 Author Posted March 2, 2016 Sorry Luke, should have mentioned that I'm running the latest beta
Nathanio 35 Posted March 2, 2016 Author Posted March 2, 2016 that doesn't look like the latest. You're right, I updated this morning. I'll check the recordings and set a few test ones
Nathanio 35 Posted March 3, 2016 Author Posted March 3, 2016 Hi Luke, 3 recordings at 9pm last night ended up with 2 converted to MP4 and showing the correct media info and one failed to transcode into an MP4 format. I still have it as a TS file which is good. Here is the failed transcode log: {"Protocol":"Http","Path":"http://172.0.0.230:5004/auto/v101","Type":"Default","Container":"ts","ReadAtNativeFramerate":false,"SupportsTranscoding":true,"SupportsDirectStream":true,"SupportsDirectPlay":true,"RequiresOpening":false,"RequiresClosing":false,"BufferMs":0,"MediaStreams":[{"Codec":"mpeg2video","IsInterlaced":true,"IsDefault":false,"IsForced":false,"Type":"Video","Index":-1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false},{"Codec":"ac3","IsInterlaced":false,"BitRate":192000,"IsDefault":false,"IsForced":false,"Type":"Audio","Index":-1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false}],"PlayableStreamFileNames":[],"Formats":[],"RequiredHttpHeaders":{}} C:\Users\Administrator\AppData\Roaming\Emby-Server\ffmpeg\20160131\ffmpeg.exe -fflags +genpts -async 1 -vsync -1 -i "http://172.0.0.230:5004/auto/v101" -t 01:02:59.678 -sn -codec:v:0 libx264 -force_key_frames expr:gte(t,n_forced*5) -vf "yadif=0:-1:0" -pix_fmt yuv420p -preset superfast -crf 23 -b:v 25000000 -maxrate 25000000 -bufsize (25000000*2) -vsync vfr -profile:v high -level 41 -map_metadata -1 -threads 0 -codec:a:0 aac -strict experimental -ab 320000 -y "E:\ServerFolders\EmbyTV\Series\DIY SOS The Big Build\DIY SOS The Big Build S24E02 Misterton.mp4" ffmpeg version N-78218-gc86ecdf Copyright (c) 2000-2016 the FFmpeg developers built with gcc 5.3.0 (GCC) configuration: --arch=x86_64 --target-os=mingw32 --cross-prefix=/home/mceuser/ffmpeg-windows-build-helpers/sandbox/cross_compilers/mingw-w64-x86_64/bin/x86_64-w64-mingw32- --pkg-config=pkg-config --disable-w32threads --enable-gpl --enable-libsoxr --enable-fontconfig --enable-libass --enable-libutvideo --enable-libbluray --enable-iconv --enable-libtwolame --extra-cflags=-DLIBTWOLAME_STATIC --enable-libzvbi --enable-libcaca --enable-libmodplug --extra-libs=-lstdc++ --extra-libs=-lpng --enable-libvidstab --enable-libx265 --enable-decklink --extra-libs=-loleaut32 --enable-libx264 --enable-libxvid --enable-libmp3lame --enable-version3 --enable-zlib --enable-librtmp --enable-libvorbis --enable-libtheora --enable-libspeex --enable-libopenjpeg --enable-gnutls --enable-libgsm --enable-libfreetype --enable-libopus --enable-frei0r --enable-filter=frei0r --enable-bzlib --enable-libxavs --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libvo-amrwbenc --enable-libschroedinger --enable-libvpx --enable-libilbc --enable-libwavpack --enable-libwebp --enable-libgme --enable-dxva2 --enable-libdcadec --enable-avisynth --enable-gray --enable-libopenh264 --enable-libmfx --extra-libs=-lpsapi --extra-cflags= --enable-static --disable-shared --prefix=/home/mceuser/ffmpeg-windows-build-helpers/sandbox/cross_compilers/mingw-w64-x86_64/x86_64-w64-mingw32 --enable-runtime-cpudetect libavutil 55. 16.101 / 55. 16.101 libavcodec 57. 24.100 / 57. 24.100 libavformat 57. 23.101 / 57. 23.101 libavdevice 57. 0.101 / 57. 0.101 libavfilter 6. 27.100 / 6. 27.100 libswscale 4. 0.100 / 4. 0.100 libswresample 2. 0.101 / 2. 0.101 libpostproc 54. 0.100 / 54. 0.100 [http @ 00000000001560e0] HTTP error 503 Service Unavailable http://172.0.0.230:5004/auto/v101: Server returned 5XX Server Error reply
Nathanio 35 Posted March 3, 2016 Author Posted March 3, 2016 Hi Luke, That's because it appears to have tried and started 3 streams on the same tuner (dual tuner models). Is that a Emby scheduling issue? Attached is all the logs from yesterday I can't see in the logs where it tries to fire all 3 programs at 9 and how it decides which tuner to use? It has recorded all 3 programs though? logs.7z
Luke 42241 Posted March 3, 2016 Posted March 3, 2016 since you're on the beta please make sure to stay on the latest. these logs are several versions ago. thanks.
