sfnetwork 514 Posted December 27, 2013 Posted December 27, 2013 (edited) movies, series, music, or all? Well, sure about TV shows and Movies. Music, absolutely no idea... ***There is no skin that I could find that actually uses the thumbs... Only NOX is "kind of" using it but it uses a combination of the fanart and logo/title to emulate a thumb. So still best to use landscape.ext as it avoid the poster issues in some skins and artwork downloader addon (which I think we can rely on) is doing this for thumbs... Edited December 27, 2013 by sfnetwork
sfnetwork 514 Posted December 27, 2013 Posted December 27, 2013 (edited) Basically, as long as there is no thumb.jpg, that what works... I can't find any confirmed (official from XBMC) information on thumbs (only for episodes) So, since the only reference we have is artwork downloader and everybody's happy (and besides the thumbs, everything is fine), here are the changes that I suggest: Thumb.jpg -> landscape.jpg seasonXX-thumb.jpg > seasonXX-landscape.jpg BUT, I wouldn't change the extra folders at all (same naming convention) Using as reference: -My own testing -http://wiki.xbmc.org/index.php?title=Add-on:Artwork_Downloader#Naming_conventions -http://wiki.xbmc.org/index.php?title=XBMC_v12_(Frodo)_FAQ#Local_images I think everybody should be happy with those changes.. Edited December 27, 2013 by sfnetwork
Luke 42289 Posted December 27, 2013 Posted December 27, 2013 it will be in the next dev build so please test and verify
sfnetwork 514 Posted December 27, 2013 Posted December 27, 2013 it will be in the next dev build so please test and verify ok
sfnetwork 514 Posted December 27, 2013 Posted December 27, 2013 (edited) @@Luke I've been testing with Fatal a bit and "landscape.ext" might be the best way to go for thumbs. In XBMC in some skins/views, when using landscape.ext, thumbs are recognized and no more of this poster issue. **I tested it with the most popular skins (MQ5, ACE, NOX, etc...) Edited December 26, 2013 by sfnetwork
zachmo826 1 Posted December 27, 2013 Posted December 27, 2013 Just to chime in on this, I've had issues with skins trying to use the thumb.jpg image instead of poster.jpg. I posted in the XBMC forms here for a specific skin thread, (http://forum.xbmc.org/showthread.php?tid=139712&pid=1564810#pid1564810) but the response was "This is because Aeon Nox uses ListItem.Art(poster) for their image where as Immersive uses the all-inclusive ListItem.Thumb." I just wanted to pass this information along to see if it helps in determining where to go next. It seems that Mediabrowser would want to use the all-inclusive naming, as I've had the same issue on a few xbmc skins, but I'm not sure if this would be a better option down the road
