KarterJK 35 Posted February 29, 2016 Posted February 29, 2016 (edited) I used to be able to display DVD cases in different styles modern, sapphire, thin style, plastic etc. But I forgot what I needed or where to go.. Any help appreciated Edited February 29, 2016 by KarterJK
Solution Happy2Play 9800 Posted February 29, 2016 Solution Posted February 29, 2016 Go to the Cover Art plugin and go to the treatment menu. If you are using beta v3.0.5891.0 plugin configs are a bit flaky right now and you may have to refresh the page. 1
KarterJK 35 Posted February 29, 2016 Author Posted February 29, 2016 Thank you very much... I knew I could do it, just forgot how
QUIKFLUX 6 Posted February 29, 2016 Posted February 29, 2016 Go to the Cover Art plugin and go to the treatment menu. If you are using beta v3.0.5891.0 plugin configs are a bit flaky right now and you may have to refresh the page. Weird, i cant seem to even get to the settings/config for the covert art plugin atm running v3.0.5891.0
