Heuer 76 Posted March 3, 2016 Posted March 3, 2016 Seems to be related to whether using windowed or full screen. Subs work in full screen not in windowed. I have a Intel i5 with on board graphics and a HTPC with Nvidia 650ti GPU..
babgvant 143 Posted March 3, 2016 Posted March 3, 2016 Seems to be related to whether using windowed or full screen. Subs work in full screen not in windowed. I have a Intel i5 with on board graphics and a HTPC with Nvidia 650ti GPU.. Full screen, I see them w/ madVR. Both windowed & full screen I see them w/ EVR+. I think the positioning must be wonky. Maybe created for a higher res video than the test file...
rblu19 3 Posted March 3, 2016 Author Posted March 3, 2016 Working for me now. Thanks. Btw, it was the download for me, not the CDN, since you're keeping track. 1
justpig 27 Posted March 3, 2016 Posted March 3, 2016 When I check the properties of EVRPresenter.dllI I get 1.0.0.6. However, I cannot get the subtitle to show, full screen or windowed, no subtitle is displayed.
justpig 27 Posted March 4, 2016 Posted March 4, 2016 There seems to be a problem with xysubfilter. When the video starts it is triggered and the icon is visible in the system tray. However, if I right click on it the selection that is ticked is no subtitle. If I manual select the subtile in xysubfilter, it shows up with madvr but it causes the video to stop playing with evr+.
babgvant 143 Posted March 4, 2016 Posted March 4, 2016 There seems to be a problem with xysubfilter. When the video starts it is triggered and the icon is visible in the system tray. However, if I right click on it the selection that is ticked is no subtitle. If I manual select the subtile in xysubfilter, it shows up with madvr but it causes the video to stop playing with evr+. Which version of XySubFilter do you have?
justpig 27 Posted March 4, 2016 Posted March 4, 2016 (edited) I checked, the version in AppData\Roaming\Emby-Theater\COMObjects is 3.1.0.746. But the text file in COMObjects is saying 2.0.0 Edited March 4, 2016 by justpig
babgvant 143 Posted March 4, 2016 Posted March 4, 2016 Can you check? Given the CDN issues, it might not be the latest rev.
justpig 27 Posted March 4, 2016 Posted March 4, 2016 I checked, the version in AppData\Roaming\Emby-Theater\COMObjects is 3.1.0.746. But the text file in COMObjects is saying 2.0.0
lang-server 2 Posted March 4, 2016 Posted March 4, 2016 Having the same issue with subtitles. Looking at the thread, I don't understand what I am suppose to do with the attached download evrpresenter.ddl ?
babgvant 143 Posted March 5, 2016 Posted March 5, 2016 Having the same issue with subtitles. Looking at the thread, I don't understand what I am suppose to do with the attached download evrpresenter.ddl ? You want to replace the version that comes w/ Emby w/ it. I deployed it to the main stream, so the next version will have it.
babgvant 143 Posted March 5, 2016 Posted March 5, 2016 I checked, the version in AppData\Roaming\Emby-Theater\COMObjects is 3.1.0.746. But the text file in COMObjects is saying 2.0.0 The # in the txt file is the version of Emby it was last updated from. That is the right sub filter.
justpig 27 Posted March 5, 2016 Posted March 5, 2016 Thanks. I have all the right elements but it still does not work.
LqHnyBear 24 Posted April 6, 2016 Posted April 6, 2016 (edited) @@babgvant I'm not seeing subs either. When I use MadVR they appear but my entire video gets shifted up with a large black bar on the bottom of the screen. Using EVR+ Stable or Edge I see the subtitles partially. They appear on the video but are cut off on the bottom. I can only see half the words. It also appears the subs only appear when the overlay is present. Here is an example of what I see. EVR+ MadVR Edited April 7, 2016 by Luke
LqHnyBear 24 Posted April 7, 2016 Posted April 7, 2016 Don't know how to make a sample of the file. I can post the media info, hopefully that helps. General Unique ID : 188628850927762444721908576504834671224 (0x8DE898617FB0481ABBF04C9ACE13C278) Complete name : Ip Man 3 (2015) [1080p] [PG-13]\Ip Man 3 (2015) [1080p] [PG-13].mkv Format : Matroska Format version : Version 4 / Version 2 File size : 2.64 GiB Duration : 1h 44mn Overall bit rate : 3 606 Kbps Encoded date : UTC 2016-04-06 19:45:10 Writing application : mkvmerge v9.0.1 ('Obstacles') 64bit Writing library : libebml v1.3.3 + libmatroska v1.4.4 Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.1 Format settings, CABAC : Yes Format settings, ReFrames : 5 frames Codec ID : V_MPEG4/ISO/AVC Duration : 1h 44mn Bit rate : 2 850 Kbps Width : 1 920 pixels Height : 816 pixels Display aspect ratio : 2.35:1 Frame rate mode : Constant Frame rate : 24.000 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.076 Stream size : 2.08 GiB (79%) Writing library : x264 core 148 r2638 7599210 Encoding settings : cabac=1 / ref=5 / deblock=1:-1:-1 / analyse=0x3:0x133 / me=umh / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=30 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=2 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=12 / lookahead_threads=3 / sliced_threads=0 / slices=4 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=5 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=2pass / mbtree=1 / bitrate=2850 / ratetol=1.0 / qcomp=0.60 / qpmin=1 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=62500 / vbv_bufsize=78125 / nal_hrd=none / filler=0 / ip_ratio=1.40 / aq=1:1.00 Language : English Default : Yes Forced : No Audio ID : 2 Format : DTS Format/Info : Digital Theater Systems Mode : 16 Format settings, Endianness : Big Codec ID : A_DTS Duration : 1h 44mn Bit rate mode : Constant Bit rate : 755 Kbps Channel(s) : 6 channels Channel positions : Front: L C R, Side: L R, LFE Sampling rate : 48.0 KHz Frame rate : 93.750 fps (512 spf) Bit depth : 24 bits Compression mode : Lossy Stream size : 565 MiB (21%) Language : Chinese Default : Yes Forced : No Text ID : 3 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 1h 39mn Bit rate : 34 bps Count of elements : 1188 Stream size : 25.4 KiB (0%) Language : English Default : Yes Forced : Yes Menu 00:00:00.000 : en:Chapter 00 00:10:09.041 : en:Chapter 01 00:18:47.333 : en:Chapter 02 00:27:50.625 : en:Chapter 03 00:37:22.208 : en:Chapter 04 00:45:58.833 : en:Chapter 05 01:00:27.708 : en:Chapter 06 01:06:29.458 : en:Chapter 07 01:15:04.000 : en:Chapter 08 01:23:09.291 : en:Chapter 09 01:30:51.541 : en:Chapter 10 01:41:39.041 : en:Chapter 11
babgvant 143 Posted April 7, 2016 Posted April 7, 2016 That is useful as it confirms that the file has a non-standard width/height, but to fix it I will need a sample that exhibits the issue. If you can't create one of these, you can upload the file somewhere (Dropbox/GDrive/OneDrive) and PM a link to me. Generally it's easiest to change the file extension or zipping it before uploading.
babgvant 143 Posted April 8, 2016 Posted April 8, 2016 You can use mkvtoolnix to cut a segment out of the file
