lcasadonte 3 Posted February 27, 2016 Posted February 27, 2016 I can not play certain channels for the life of me that have drm on using the hdhomerun through the dlna tuner in emby. I have a cable tuning adapter and everything in terms of authorization is positive. This is what i get in my hdhomerun log: HDHomeRun PRIME System Log 19700101-00:00:00 System: reset reason = power on19700101-00:00:01 CableCARD: M-CARD inserted19700101-00:00:01 CableCARD: invalid session 0xDEAD (cchost_session:267)19700101-00:00:03 System: network link 1000f19700101-00:00:04 System: ip address obtained: 198.202.196.177 / 255.255.255.019700101-00:00:06 CableCARD: Cisco card (0103:0001)19700101-00:00:10 CableCARD: authentication status: authentication in progress19700101-00:00:10 CableCARD: authentication status: authentication success, validation success19700101-00:00:17 CableCARD: USB device 05A6:0008 connected19700101-00:00:17 CableCARD: Tuning Resolver connected19700101-00:00:18 CableCARD: Tuning Resolver downstream status: success19700101-00:00:18 CableCARD: Tuning Resolver upstream status: success19700101-00:00:18 CableCARD: Tuning Resolver authentication status: in progress19700101-00:00:18 CableCARD: Tuning Resolver operational status: initializing19700101-00:00:19 CableCARD: Tuning Resolver authentication status: success19700101-00:00:19 CableCARD: Tuning Resolver operational status: ready19700101-00:01:11 Tuner: tuner0 streaming rtp to 198.202.196.195:5526219700101-00:01:11 Tuner: tuner0 tuning 1063 MTVHD (none:375MHz-1)19700101-00:01:12 CableCARD: tuner0 1063 MTVHD (none:375MHz-1) access = subscribed19700101-00:01:17 Tuner: tuner0 streaming rtp to 198.202.196.195:5358819700101-00:01:17 Tuner: tuner0 tuning 1062 BRVHD (none:255MHz-4)19700101-00:01:18 CableCARD: tuner0 1062 BRVHD (none:255MHz-4) access = subscribed19700101-00:01:47 Tuner: tuner0 streaming rtp to 198.202.196.195:5011219700101-00:01:47 Tuner: tuner0 tuning 1064 VH1HD (none:357MHz-4)19700101-00:01:47 CableCARD: tuner0 1064 VH1HD (none:357MHz-4) access = subscribed19700101-00:02:01 Tuner: tuner0 streaming rtp to 198.202.196.195:6534719700101-00:02:01 Tuner: tuner0 tuning 1062 BRVHD (none:255MHz-4)19700101-00:02:02 CableCARD: tuner0 1062 BRVHD (none:255MHz-4) access = subscribed20160227-22:24:47 CableCARD: time changed from Thu Jan 01 00:03:28 1970 to Sat Feb 27 22:24:47 201620160227-22:50:46 Tuner: tuner2 streaming rtp to 198.202.196.195:500120160227-22:50:46 Tuner: tuner2 tuning 1062 BRVHD (none:255MHz-4)20160227-22:50:47 CableCARD: tuner2 1062 BRVHD (none:255MHz-4) access = subscribed20160227-22:53:08 Tuner: tuner2 streaming rtp to 198.202.196.195:500120160227-22:53:08 Tuner: tuner2 tuning 1062 BRVHD (none:255MHz-4)20160227-22:53:09 CableCARD: tuner2 1062 BRVHD (none:255MHz-4) access = subscribed No picture. Every version of emby has wanted to identify and own the prime tuner and if I try to use the serverwmc plugin w/windows media center they compete for the prime. I can't turn of the dlna hdhomerun (its picked up automatically) and it seems I can't play these channels outside of media center even in hdhomeruns viewer software. Any ideas on how to turn off the dlna hdhomerun or get the drm channels with it?
Luke 42186 Posted February 27, 2016 Posted February 27, 2016 Hi, the channels with drm are only going to be playable in hdhomeruns software as they had additional security measures added.
lcasadonte 3 Posted February 27, 2016 Author Posted February 27, 2016 (edited) Thanks, The hdhomerun software wont play the channels but media center does. I'd like to use serverwmc instead of the dlna version of the hdhomerun prime but can't stop the dlna server from coming back. I posted under windows server because I can't switch between the dlna server and serverwmc. Let me know if I posted in the wrong forum and thanks again, Edited February 27, 2016 by lcasadonte
lcasadonte 3 Posted February 28, 2016 Author Posted February 28, 2016 (edited) Thanks latchmor for posting the solution in another post. Just deactivate the dlna tuner not delete it as I was doing foolishly. Thanks, Edit 3-5-16 - just for others, I am still missing drm channes and they can't be played without wmc playing them directly. ServerWMC allows me to have the older OTA tuner and the prime concurrently w/one guide so it is still useful. Thanks for the help. Edited March 5, 2016 by lcasadonte
