Habanero Gabe 0 Posted February 27, 2016 Posted February 27, 2016 (edited) Using StartSSL.com I was able to make a free certificate and it works well accessing my qnap remotely. Using the StartSSL.com wizard I created a pfx (.p12), but I can't get the cert to work in Emby. If I delete my cert path to allow it to make a self-signed cert, I can access Emby remotely with a web browser (emby.my-domain-example.com:8920) with the expected self-signed cert warning prompt. But I have the following problems: Using the self-signed cert none of my Emby mobile apps will connect. http://app.emby.media/ can't connect to my Emby server Any ideas? Edited February 27, 2016 by Habanero Gabe
Habanero Gabe 0 Posted March 2, 2016 Author Posted March 2, 2016 Has anyone been able to get ssl working in Emby?
Luke 42239 Posted March 2, 2016 Posted March 2, 2016 the self signed cert requires a lot of work in all the emby apps. We're going to be revamping our SSL support soon and switching to something along the lines of LetsEncrypt.
Habanero Gabe 0 Posted March 2, 2016 Author Posted March 2, 2016 That's good to know. I was trying ssl (self signed or ca signed) because when my wife was at the hospital, Emby was blocked on their wifi. We could use Netflix, but no Emby. Was hoping to overcome the blocks with ssl should we be in a location again that blocks Emby.
somy 25 Posted September 1, 2016 Posted September 1, 2016 Same problem here! Also use StartSSL certificate in PFX format without luck.
