rendez2k 0 Posted February 26, 2016 Posted February 26, 2016 I have the latest iOS Emby installed, and both versions of the Chromecast. Emby will see the Chromecast, the Emby logo comes on the TV but I can't then press the play button on the phone! Any ideas? Tried removing and reinstalling the app.
Luke 42243 Posted February 26, 2016 Posted February 26, 2016 Hi, I have not seen this but will test it out, thanks.
Songs 0 Posted March 5, 2016 Posted March 5, 2016 any update on this? I have similar issue, I have chromecast gen1, which works fine with other apps such as Youtube, etc. I installed EMBY server, and using emby client to cast to chromecast. It detected chromecast, and screen shows ready to cast, select your media in EMBY and play it here. Then I go back to client, tried play button, nothing happened. I tried it using all clients, from IOS, web browser, and android, same symptom. I can broswer the media library, but hitting play button has no effect using all clients. I also tried removing and reinstalling the app, still same problem. please help.
Songs 0 Posted March 22, 2016 Posted March 22, 2016 is there any update or any suggestion on this?It's still stuck at the playing. please help. I can click that cast icon to connect to chromecast, and TV shows ready to cast, select your media in EMBY and play it here. but EMBY client play button has no effect t all. If it really can't work, I have to try other solutions.
Songs 0 Posted March 23, 2016 Posted March 23, 2016 another naive question: can EMBY play to chromecast first gen? since I'm using first gen device, and I still had no clue why it did nothing after click play. second naive question: do I have to unlock the app to be able to play to chromecast? thanks for the clarification in advance.
Luke 42243 Posted March 24, 2016 Posted March 24, 2016 another naive question: can EMBY play to chromecast first gen? since I'm using first gen device, and I still had no clue why it did nothing after click play. second naive question: do I have to unlock the app to be able to play to chromecast? thanks for the clarification in advance. Hi, welcome, yes, they're both supported. Can you please provide a server log from a playback attempt? Please see how to report a problem for instructions. Thanks.
