Flanity 0 Posted February 26, 2016 Posted February 26, 2016 Hi, Metadata Manager was working a couple days ago as normal. Today, when I click on a folder to expand it the arrow just goes grey and it doesn't expand (show the shows/movies etc in that folder) Is anyone else experiencing this? Many thanks in advance for any help or advice you can offer
Happy2Play 9800 Posted February 26, 2016 Posted February 26, 2016 I see this in the current beta 5887 but it work properly in current dev and stable versions
Flanity 0 Posted February 26, 2016 Author Posted February 26, 2016 Thank you for your speedy reply, could you tell me if it's possible to revert back to the stable release and if so, how? Many thanks x
Happy2Play 9800 Posted February 26, 2016 Posted February 26, 2016 (edited) You should have any issues just installing the stable over the beta since all the database updates are already pushed to stable. http://emby.media/windows-server.html There should be another beta update in soon also. Edited February 26, 2016 by Happy2Play
Flanity 0 Posted February 26, 2016 Author Posted February 26, 2016 Wow.... that's quick work! Thank you so much for the great job you all do, hugely appreciated x
Luke 42186 Posted February 26, 2016 Posted February 26, 2016 As always, thank you for helping to test this pre-release version of Emby Server.
