casminkey 19 Posted February 25, 2016 Posted February 25, 2016 Hello, I noticed I only have guide data for 2 channels, so did a manual refresh. The task just sits at 0.0%. I made sure my SchedulesDirect membership is active, and configured correctly in Emby. Here's what I found from the log, saying target machine is refusing connection (entire log attached): 2016-02-25 18:00:09.9625 Info TaskManager: Executing Refresh Guide 2016-02-25 18:00:09.9625 Info HttpServer: HTTP Response 204 to ::1. Time: 7ms. http://localhost:8096/emby/ScheduledTasks/Running/3c6a16ed7db828baeb3bb3c1cff74810 2016-02-25 18:00:09.9865 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks?isHidden=false. UserAgent: Mozilla/5.0 (Windows NT 6.3; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/48.0.2564.116 Safari/537.36 2016-02-25 18:00:09.9865 Info HttpServer: HTTP Response 200 to ::1. Time: 3ms. http://localhost:8096/emby/ScheduledTasks?isHidden=false 2016-02-25 18:00:11.0044 Error App: Error refreshing channels for service *** Error Report *** Version: 3.0.5871.0 Command line: C:\Users\Curt\AppData\Roaming\Emby-Server\System\MediaBrowser.ServerApplication.exe Operating system: Microsoft Windows NT 6.2.9200.0 Processor count: 4 64-Bit OS: True 64-Bit Process: True Program data path: C:\Users\Curt\AppData\Roaming\Emby-Server Application Path: C:\Users\Curt\AppData\Roaming\Emby-Server\System\MediaBrowser.ServerApplication.exe No connection could be made because the target machine actively refused it [::1]:9080 System.Net.Sockets.SocketException at wmc2mb.SocketClientAsync.<GetVectorAsync>d__0.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at wmc2mb.WMCService.<isServerDown>d__2.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at wmc2mb.WMCService.<GetChannelsAsync>d__22.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Server.Implementations.LiveTv.LiveTvManager.<GetChannels>d__fe.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Server.Implementations.LiveTv.LiveTvManager.<RefreshChannelsInternal>d__d3.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Server.Implementations.LiveTv.LiveTvManager.<RefreshChannelsInternal>d__c4.MoveNext() Anyone have any idea's? Or is this an issue with Schedules Direct? server-63592017684.txt
casminkey 19 Posted February 25, 2016 Author Posted February 25, 2016 Disregard. It took about 45 minutes but did eventually finish and guide is updated.
Luke 42237 Posted February 26, 2016 Posted February 26, 2016 Glad you sorted it out. Fyi, the above usually happens when you don't have server wmc running, or the emby server plugin is unable to connect to the server wmc application for whatever reason.
