ubertoast 2 Posted February 25, 2016 Posted February 25, 2016 (edited) I can't seem to get api remote commands to work with the new Emby Theater. I have tried on windows 10 and windows 7. I have tried sending commands from the web client on Chrome as well as Emby on Android (by selecting Emby Theater as the "Play To" device). Whenever I select play, nothing happens on Emby Theater. I am able to use the remote feature to control other devices (I am able to do web client to web client, android to web client, web client/android to MPC Remote) Note that MCE remote controls DO work (using unified remote or other similar apps) Any idea what may be causing this? Edited February 25, 2016 by ubertoast
Luke 42241 Posted February 25, 2016 Posted February 25, 2016 Hi, for the new Emby Theater app it's currently not implemented yet. It's on the roadmap to be added soon. Thanks.
griam01 14 Posted February 27, 2016 Posted February 27, 2016 Sorry for adding to this thread, does that mean the remote within the ios app does not work with theater, or any remote commands do not work? I use FLIRC with a Harmony remote and I had everything configured to work. Once I upgraded to the new version, the arrow buttons work to navigate, but that is about it. I had not tried the remote within the ios app yet. Just wanted to figure out what is to be added soon, so I know what should work and what shouldn't. Thanks.
