dejavux2 47 Posted February 25, 2016 Posted February 25, 2016 Hello! When Emby Server updated today, the latest Dev Version 3.0.5899.15688 reset the Home Screen Settings, and put checkmarks back on everything. This affects Emby Classic.
Luke 42186 Posted February 25, 2016 Posted February 25, 2016 Hi, I'm pretty sure it did not do that. What makes you think that happened?
dejavux2 47 Posted February 25, 2016 Author Posted February 25, 2016 Because before the update, I had no checkmarks on the Home Screen Settings, so that my Entry Points stay separated and not grouped. After the update, the checkmarks were all back, and media was grouped.
Happy2Play 9800 Posted February 25, 2016 Posted February 25, 2016 Upgraded to 3.0.5899.15688 and then to 3.0.5899.27910 and with both updates "My Views" remained unchecked\ungrouped.
dejavux2 47 Posted February 25, 2016 Author Posted February 25, 2016 I have gone through and removed the checkmarks again. I will now update to 3.0.5899.27910 and report back....
dejavux2 47 Posted February 25, 2016 Author Posted February 25, 2016 Ok... updated to 3.0.5899.27910, and all is well... checkmarks did not reappear on Home Screen Settings...
Luke 42186 Posted February 25, 2016 Posted February 25, 2016 Thank you for testing these pre-release versions of the software.
