Abobader 3485 Posted March 5, 2016 Posted March 5, 2016 @@Abobader hope you feel better soon. Try out 2.2.8, let me know that it works, *double crossing my fingers*... Good day, Well done buddy, well done indeed. All fine now, great work. I just wonder why the indication bar freeze as you see in the image. My best 1
Angelblue05 4132 Posted March 5, 2016 Posted March 5, 2016 I'll look into it. Does this happen regularly or just when you update versions @@Abobader? @@LongMan sure Sent from my iPhone using Tapatalk
Abobader 3485 Posted March 5, 2016 Posted March 5, 2016 I'll look into it. Does this happen regularly or just when you update versions @@Abobader? Sent from my iPhone using Tapatalk Good day, Seems when update ver as I notice this. My best
Angelblue05 4132 Posted March 5, 2016 Posted March 5, 2016 I can also confirm that it is showing all photos. I have a similar setup. I was thinking I did something wrong but all photos as showing now. Thanks @@Angelblue05. Are able to include the file name of the picture? When Picture Information(info on remote, i on keyboard) screen comes up, File name says '0'. It would be nice to have the file name. Cheers, LongMan @@marcelveldt Is it possible to set that info?
LongMan 117 Posted March 6, 2016 Posted March 6, 2016 Thanks. I give a go once you are ready to test. LongMan
marcelveldt 736 Posted March 7, 2016 Posted March 7, 2016 @@marcelveldt Is it possible to set that info? I believe I already tried that but because the pictures itself are retrieved through HTTP the filename is empty If I recall correctly I've set the picture name/label to the filename instead
Angelblue05 4132 Posted March 7, 2016 Posted March 7, 2016 (edited) @@marcelveldt I see. I was checking another pictures add-on to compare (the name is XKCD). It also uses http, but the filename is not empty somehow. Edited March 7, 2016 by Angelblue05
