Abobader 3485 Posted March 4, 2016 Posted March 4, 2016 I will test it later today buddy, sorry not feeling well at the moment (sort throat issue). Well done.
Abobader 3485 Posted March 4, 2016 Posted March 4, 2016 @@Abobader Grab the latest 2.2.7 in public testing again. I think I got this right, now. I've tested with the exact naming of your photo library just to make sure. Same issue buddy as post #24, here the log: kodi.log
Angelblue05 4132 Posted March 4, 2016 Posted March 4, 2016 (edited) @@Abobader You don't have the zip installed from the public testing. Try again to install it please. Thanks, it should work. As I said, I've already tested it, there's no reason why it wouldn't work for you as well (but you have the wrong version installed, that does not contain any fixes I made). I've attached it here, just in case. Edited March 5, 2016 by Angelblue05
Abobader 3485 Posted March 4, 2016 Posted March 4, 2016 Good day, Buddy I am sure I download .27, but I went a head and download the zip file here, run it, update start for 15 items, it been like this for this item for the past 30 mins or so, here the log: kodi.log I can access that network share and play the titles without any problem. My best
Angelblue05 4132 Posted March 4, 2016 Posted March 4, 2016 (edited) According to your log, the update has completed. It seems however, that you installed the version during the sync so the progress dialog never closed. Just restart Kodi to be safe, but it should be fine. Let me know if your pictures are working now. Thanks. Edit: And no, you had the incorrect version installed. This was the error you were getting in your log. utils.logMsg("BrowseContent","viewname: %s - type: %s - folderid: %s - filter: %s" %(viewname, type, folderid, filter)) UnicodeDecodeError: 'ascii' codec can't decode byte 0xd8 in position 10: ordinal not in range(128) This what the custom build 2.2.7 looks like with the fix: utils.logMsg("BrowseContent","viewname: %s - type: %s - folderid: %s - filter: %s" %(viewname.decode('utf-8'), type.decode('utf-8'), folderid.decode('utf-8'), filter.decode('utf-8'))) Edited March 4, 2016 by Angelblue05
Abobader 3485 Posted March 4, 2016 Posted March 4, 2016 Good day, Thing at the moment not good, now I can not see my folder library name for pictures as it used to be: Sorry to ask, but where to find the build number for the one installed? My best
CBers 7554 Posted March 4, 2016 Posted March 4, 2016 Sorry to ask, but where to find the build number for the one installed? My best GOTO Settings, Add-ons, My Add-ons, Video Add-ons, Emby. It should then show you the version you have installed. I have 2.2.7 installed. 2
Angelblue05 4132 Posted March 4, 2016 Posted March 4, 2016 I don't understand this at all. What on earth is going on. It's working just fine for me over here. Instead of launching the emby add-on, just open the context menu on Emby > add-on information. It should say 2.2.7 1
Angelblue05 4132 Posted March 4, 2016 Posted March 4, 2016 Proof. I will push a new beta version 2.2.8 with the photo fixes, in case something is wrong on your side.
Abobader 3485 Posted March 4, 2016 Posted March 4, 2016 ah, ok I give up, maybe my kodi for emby have sort throat issue as I am I will try later. Well done CBers and Angelblue. 2
CBers 7554 Posted March 4, 2016 Posted March 4, 2016 @@Angelblue05 - where are the instructions for adding Photos to Kodi please? I think I have done it correctly, but I'm only seeing a 3rd if my Photos folders listed. Thanks.
Angelblue05 4132 Posted March 4, 2016 Posted March 4, 2016 @@CBers Your emby photo libraries are accessed via picture add-ons > emby Let me know your structure a bit. How are they added to emby? Are they grouped? Are they individual folders in your emby dashboard > library? Let me know.
CBers 7554 Posted March 4, 2016 Posted March 4, 2016 I have a Photos library that then contains Years, under which are Months, then either Events folders or photos or both. I have Year folders from 1999 - 2015, but only seeing a few of them. So in the skin I use (Mimic), I just create a menu option pointing to Addon, Picture Addon, Emby, Photos, "create menu item to here" ? If I go into the Photos before selecting "create menu item to here", I don't get the full listing of my Photos folder. 1
Angelblue05 4132 Posted March 4, 2016 Posted March 4, 2016 (edited) I have a Photos library that then contains Years, under which are Months, then either Events folders or photos or both. I have Year folders from 1999 - 2015, but only seeing a few if them. So in the skin I use (Mimic), I just create a menu option pointing to Addon, Picture Addon, Emby, Photos, create menu item to here ? Yes, that's correct for the menu. Sorry, you said you are missing year folders or months / events / photos? Edit: Just saw your other post. Ok so years is missing. Hmm, looking into what could explain this.... picture libraries are pulled "instantly" from the server, but for some reason they don't have an entry created for them. Edited March 4, 2016 by Angelblue05 1
CBers 7554 Posted March 4, 2016 Posted March 4, 2016 Structure: Photos-> 1999-> 01. January 02. February 2000-> 01. January 02. February-> Event 1 Event 2 And so on. 1
CBers 7554 Posted March 4, 2016 Posted March 4, 2016 They're all showing in the web client, ATV apps as well as the Samsung Smart TV app. Not a major issue for now, but if you have some suggestions, it would be appreciated. Getting late here in the UK, so I'll pick this up tomorrow if you have any thoughts overnight. Thanks. 1
Angelblue05 4132 Posted March 4, 2016 Posted March 4, 2016 I've created a temp structure to try and replicate. The years that are missing in Kodi, are there any differences from the ones working? Maybe empty folders? Let me know.
CBers 7554 Posted March 4, 2016 Posted March 4, 2016 No, none are empty, otherwise they wouldn't exist, although they may not have pictures in them, they will have event folders with pictures in. I'll have to check the missing ones and report back 1
CBers 7554 Posted March 4, 2016 Posted March 4, 2016 Yes, that's what it is. There are no pictures directly under the Year folder, but there are Month folders that contain either Event folders and/or photos. Every one that is missing in Kodi is like this. 1
Angelblue05 4132 Posted March 4, 2016 Posted March 4, 2016 It seems I'm able to replicate the issue... I think. I'll work on it, I should have a new build out tonight, so you'll be able to test tomorrow. Thanks for letting me know.
CBers 7554 Posted March 4, 2016 Posted March 4, 2016 No, thank you for looking at it. Hopefully this fits in with @@Abobader's issue.
Angelblue05 4132 Posted March 5, 2016 Posted March 5, 2016 @@CBers your issue is fixed with the latest beta 2.2.8 @@Abobader hope you feel better soon. Try out 2.2.8, let me know that it works, *double crossing my fingers*... 2
CBers 7554 Posted March 5, 2016 Posted March 5, 2016 Thanks for the latest beta release @@Angelblue05, I'll give it a go Hopefully it'll fix @@Abobader's problem as well. 1
CBers 7554 Posted March 5, 2016 Posted March 5, 2016 Thanks @@Angelblue05, all Photos folders are now showing 1
LongMan 117 Posted March 5, 2016 Posted March 5, 2016 I can also confirm that it is showing all photos. I have a similar setup. I was thinking I did something wrong but all photos as showing now. Thanks @@Angelblue05. Are able to include the file name of the picture? When Picture Information(info on remote, i on keyboard) screen comes up, File name says '0'. It would be nice to have the file name. Cheers, LongMan 1
