NullMind 22 Posted February 23, 2016 Posted February 23, 2016 For a couple of days now, my embryo won't download the episode info, I added a new show for example and t downloaded the show info, but the individual episodes it won't, I try a manual identify but after I hit submit I just get the spinner loader and won't go beyond it, just stays there for minutes with no result page or anything Any ideas ?
NullMind 22 Posted February 23, 2016 Author Posted February 23, 2016 I see this on the logs: 2016-02-23 22:44:55.9230 Error NotFoundHttpHandler: 127.0.0.1:8096 Request not found: /emby/Items/RemoteSearch/Episode 2016-02-23 22:44:55.9230 Info HttpServer: HTTP Response 404 to 127.0.0.1. Time: 1ms. http://localhost:8096/emby/Items/RemoteSearch/Episode
NullMind 22 Posted February 23, 2016 Author Posted February 23, 2016 In "Metadata -> Services -> Episode" I do have TheTVDB enabled .. fyi
Luke 42186 Posted February 24, 2016 Posted February 24, 2016 Hi there, can you provide a specific example? Please see how to report a problem for more details. Thanks.
NullMind 22 Posted February 24, 2016 Author Posted February 24, 2016 Sure Example. Twin Peak, Episode 1 I tried entering just the name "Pilot" and search .. nothing, I tried the name and tvdb id of "11673" .. search .. nothing, I tried removing everything and just leaving the tvdb id of 11673 .. also didn't work .. just keeps spinning
NullMind 22 Posted February 24, 2016 Author Posted February 24, 2016 Ok, here is what I found If instead of using "identify" I went to the metadata manager, and in the episode edited the episode number (season was already set) and hit "full refresh" it edit itself with the right metadata But using the "identify" it won't go nowhere .. so while I have a work around, any ideas what can cause it ?
Luke 42186 Posted February 24, 2016 Posted February 24, 2016 There isn't an Identify feature for episodes at the moment. The only way an episode is going to get metadata is if it has season and episode numbers. Does that make sense?
Sammy 790 Posted February 24, 2016 Posted February 24, 2016 A full log is always helpful. TV Series have to be properly organized by folders Series Name/Season Number/Episode Number and name like this: Series Name/S01/S01E01 - Episode Name.mkv for proper scraping. This hasn't changed in years.
