jds828 24 Posted February 23, 2016 Posted February 23, 2016 I'm thinking of getting a remote and receiver for a Windows PC. I've looked at Flirc as the receiver but the remotes range from the really nasty £5 specials on Ebay to £100's for those posh jobs with screens built into them. I don't mind paying for a decent one I can move between PC's (All Windows) but I can't justify the top end ones prices. Up to £100 for both...Any ideas?
CFC 25 Posted February 23, 2016 Posted February 23, 2016 If I were using FLIRC, I'd probably go for the peanut style Tivo remotes like this one: http://www.ebay.com/itm/NEW-TiVo-Remote-Control-For-TiVo-Premiere-Series4-TCD746320-/181919480515?hash=item2a5b3efac3:g:eWEAAOSwaA5WjVUJ otherwise, the basic RC6 type Windows Media Center remotes work pretty well also. Good luck. CFC 1
jds828 24 Posted February 23, 2016 Author Posted February 23, 2016 Thanks CFC I use an RC6 (Toshiba) on my NUC but not all the buttons work. I've looked for an editor but never came up with anything. The Toshiba remote is ok, a bit on the big side. I have a spare one that could be used but wasn't sure it would work with FLIRC.
CFC 25 Posted February 23, 2016 Posted February 23, 2016 I don't have a FLIRC receiver, but their claim to fame is that they can work with "any" remote out there. CFC
jds828 24 Posted February 24, 2016 Author Posted February 24, 2016 I've ordered the FLIRC. Bit cheaper than I thought at £18 I'm going to test it on the Toshiba RC6 remote for now and look for a better remote over the coming weeks.
chef 3811 Posted February 24, 2016 Posted February 24, 2016 Thanks CFC I use an RC6 (Toshiba) on my NUC but not all the buttons work. I've looked for an editor but never came up with anything. The Toshiba remote is ok, a bit on the big side. I have a spare one that could be used but wasn't sure it would work with FLIRC. I have used "intelli-remote" as an editor in the past and it worked well for me 2
jds828 24 Posted February 24, 2016 Author Posted February 24, 2016 Thanks chef. I've just downloaded the files so I'll look when I get back from work.
