bkscott 2 Posted February 23, 2016 Posted February 23, 2016 Hi--I had a nicely working OSX server on a Mac Mini but since the most recent update, I can't seem to schedule recordings. I am able to get through the guide and set up the record series, but then my "Scheduled Recordings" tab remains empty. The series all show up in the series tab. I initially thought that I might just need to wait for the schedule to refresh or until closer to the recording date, but the recordings I had scheduled did not record. Everything else seems to be working. Any thoughts? Thanks.
Luke 42237 Posted February 23, 2016 Posted February 23, 2016 Hi, welcome. Can you please run the refresh guide operation under Live TV setup, then provide the server log? http://emby.media/community/index.php?/topic/739-how-to-report-a-problem/ Thanks.
bkscott 2 Posted February 23, 2016 Author Posted February 23, 2016 Here is my log. I figured out that the guide refresh is failing, but I have re-entered my schedules direct info and it is still failing. Error Log_Emby_2_23_16.txt
Luke 42237 Posted February 24, 2016 Posted February 24, 2016 where is it failing? i see lots of traffic in this log to schedules direct and it all appears to be successful. Also I would make sure to run the latest version of the server.
bkscott 2 Posted February 24, 2016 Author Posted February 24, 2016 It appears to refresh successfully, and then I get a message in the notifications tab that says refresh failed because it can't have a null value for source. I tried deleting and resetting Schedules Direct as the guide source, and I updated to the latest server version. When I look at the Live TV, I do have the guide, and I am able to select a show and set up recording, I just don't get anything in the scheduled recordings and no shows have been recorded since this started happening. In the series, tab, all the shows I set up to record are listed. Thanks for you help, I really appreciate it.
Luke 42237 Posted February 24, 2016 Posted February 24, 2016 Right ok, I see that error. I would grab 3.0.5871 from the website, then let me know if you continue to see that error. thanks.
bkscott 2 Posted February 24, 2016 Author Posted February 24, 2016 Upgraded to latest version, restarted, re-added schedules direct. Once again looks as though guide is refreshing, and then same error: Value cannot be null. Parameter name: source
Luke 42237 Posted February 24, 2016 Posted February 24, 2016 Hi, if you would like, please try this build. You'll need to run a guide refresh after installing. Also be aware it's based on the dev branch, so it's going to have other features and changes that are still a work in progress. But it may help with this issue. Thanks. Emby.Server.Mac-.zip
bkscott 2 Posted February 25, 2016 Author Posted February 25, 2016 Thanks--I will give it a try. Really appreciate your help and quick responses! I will let you know how it works. 1
bkscott 2 Posted March 5, 2016 Author Posted March 5, 2016 Sorry for the delay. Tried that build and it didn't work either. I am thinking I will try totally uninstalling and reinstalling the server. Let you know what happens.
Luke 42237 Posted March 5, 2016 Posted March 5, 2016 There's already a new release up on the website so you should try that and then report back. If you're still having an issue, please provide the server log and i'll look into it right away. thanks.
bkscott 2 Posted March 16, 2016 Author Posted March 16, 2016 Still not working--I tried to completely uninstall and do a fresh install, but it appears that I didn't actually clear the old install completely from the system because the new install remembered my paths and some settings. In any case, I have the up to date server running and am still unable to get recording to work. The guide appears to be refreshing, and then gives me the same error. Value cannot be null. Parameter name: source. Here is the log. Thanks for your help! Log.txt
Luke 42237 Posted March 17, 2016 Posted March 17, 2016 Can you please try this attached version? We did finally see something similar to this on Windows and Linux, and a fix was made. This build is the equivalent of the windows beta right now. Thanks. Emby.Server.Mac-.zip
bkscott 2 Posted March 18, 2016 Author Posted March 18, 2016 Thanks for getting back to me so promptly. I will give this a try and report back.
Luke 42237 Posted March 18, 2016 Posted March 18, 2016 If you havent' done it yet, hang on I'll whip up a new one from the latest.
bkscott 2 Posted March 20, 2016 Author Posted March 20, 2016 Seems to be working so far. Thanks for sticking with this--I really appreciate your help. Keep up the good work. 1
