Direct Play from HDHomeRun to Xbone?
Seeing as the Xbone can direct play from a HDHomeRun using the Media Player as a DLNA browser from the HDHomeRun device itself, could it be possible to use Emby to control DLNA playback of HDHomeRun streams rather than having to pick up the Xbone controller and jump through the Media Player menus and browse the HDHomeRun?
As I've got two HDHomeRuns at the moment should Emby be recording, if I want to watch TV from the HDHomeRun directly from the HDHomeRun device itself on the Xbone (to avoid transcoding through Emby) it's a case of guessing to see which device I can use to watch TV.
I'm going to have a fidle with the Xbone profile to see if I can get the .ts Emby recordings to Direct Play over DLNA, but I don't expect I'll be able to tweak the profile for the stream from the HDHomeRun will I?
Cheers
mini
