yakirp88dell 1 Posted February 23, 2016 Posted February 23, 2016 hi there, when will be an option to emby connect on the kodi addon? thanks 1
Solution xnappo 1611 Posted February 23, 2016 Solution Posted February 23, 2016 It is high on the list on the Trello board and @@Angelblue05 says it is one of the next things to implement. https://trello.com/b/qBJ49ka4/emby-for-kodi 1
NullMind 22 Posted February 23, 2016 Posted February 23, 2016 What will that do ? allow Kodi to connect to a remote Emby server ?
Angelblue05 4132 Posted February 23, 2016 Posted February 23, 2016 Here is what emby connect does: https://github.com/MediaBrowser/Wiki/wiki/Emby%20Connect Essentially, all I'll be doing is allowing you to login using your emby connect credentials, and then select which server you wish to import to Kodi.
