Brendon 128 Posted December 20, 2013 Posted December 20, 2013 (edited) As the title says, how does MBS go about getting the audio/video info and where is it stored? I am asking as i have run into a problem, not sure if it's MBS or CoverArt, i have my collection sorted by definition not type and have had no problems until now.... Two movies in my collection Night at the Museum 1 and 2, put seperately in the movies folder they are seen correctly as 720p and given the blu-ray cover, however if i drop them in a folder as a collection they change to the DVD cover that i use for anything below 720p, take them out and they go back to the blu-ray cover Now i have had a couple of movies incorrectly detect the definition (not in boxes), have removed them from server access and put them back after 10mins and they detect correctly, tried this several times over 24hrs with these 2 and no go, i should also say this hasn't been a problem with any of the 50+ box sets i have already added, just these 2 movies so far and i know the .mkv rips are good i did them and mediainfo confirms they are indeed 720p/6 channel. So i figure if i know where and how this info is gathered, (now mediainfo is defunct for MB), i can find out why Edited December 20, 2013 by Brendon
ebr 16354 Posted December 20, 2013 Posted December 20, 2013 We use FFProbe and it is the width that will matter as far as resolution is concerned. I think >1200 = 720p and >1900 = 1080.
Brendon 128 Posted December 20, 2013 Author Posted December 20, 2013 yep i know what the definitions are as i said mediainfo confirms they are (below) and placed seperately so does MBS, not once they are in a collection folder though. Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L3.1 Format settings, CABAC : Yes Format settings, ReFrames : 2 frames Codec ID : V_MPEG4/ISO/AVC Duration : 1h 48mn Bit rate mode : Variable Bit rate : 5 070 Kbps Maximum bit rate : 7 773 Kbps Width : 1 280 pixels Height : 692 pixels Display aspect ratio : 1.85:1 Frame rate mode : Constant Frame rate : 23.976 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.239 Stream size : 3.85 GiB (87%) Default : Yes Forced : No Audio ID : 2 Format : AC-3 Format/Info : Audio Coding 3 Mode extension : CM (complete main) Format settings, Endianness : Big Codec ID : A_AC3 Duration : 1h 48mn Bit rate mode : Constant Bit rate : 640 Kbps Channel(s) : 6 channels Channel positions : Front: L C R, Side: L R, LFE Sampling rate : 48.0 KHz Bit depth : 16 bits Compression mode : Lossy Stream size : 497 MiB (11%) Language : English Default : Yes Forced : No It's been driving me nuts all night why do they change just for putting them inside another folder as i have done with 100 other movies lol
Brendon 128 Posted December 20, 2013 Author Posted December 20, 2013 yes ebr boxset, i put them in a folder and use the collection.xml haven't had an issue until now
ebr 16354 Posted December 20, 2013 Posted December 20, 2013 Moving their location doesn't cause a different CA profile to come into effect does it? Perhaps a server log from when one of these items is treated by CA would lend a clue as well.
Brendon 128 Posted December 20, 2013 Author Posted December 20, 2013 i'll grab a log when the kids go to sleep mate, then i can get a clean one without everyone connected easier for the reading.
Brendon 128 Posted December 28, 2013 Author Posted December 28, 2013 @@ebr just letting you know i haven't forgotten to do this mate but i have had it happen on other movies now, both my rips and downloads, so conducting a few of my own tests atm.
