sylvio2000 23 Posted February 22, 2016 Posted February 22, 2016 1. I use Emby for FireTV and want to know how I can wol my Emby Server when starting the app. 2. Is there another option to fast forward instead of only jumping in 30s intervalls? If you are watching a long movie this can be very frustrating.
ebr 16336 Posted February 22, 2016 Posted February 22, 2016 1. I use Emby for FireTV and want to know how I can wol my Emby Server when starting the app. We are already attempting to do that but there have been reports that, with Android, it may not be reliable. We will have to investigate further. 2. Is there another option to fast forward instead of only jumping in 30s intervalls? If you are watching a long movie this can be very frustrating. Yes. Use the chapter points.
sylvio2000 23 Posted February 23, 2016 Author Posted February 23, 2016 Wol is really important for the WAF I think . Hope you find a solution. Yes, you are right, there are chapter points. But I think this is not the best solution. It would be better to directly control the slider with a long press to the right or left direction (like netflix). Or like Kodi where I can use all 4 directions to jump greater intervalls.
