JBL 8 Posted February 22, 2016 Posted February 22, 2016 Hi Everyone, First, it goes without saying that Emby is really sweet, the devs have done, and continue to do, an awesome job! Quick question in regards to the icons for the Trailers and Collections channels (I think they're channels...?). Currently, across all of my clients, the icons for the Collections and Trailers Channel look like this: Is there any way to change them to something custom? With my regular library icons, I built little collages out of covers from my movie, music and TV collections. Thanks! JBL
Solution Luke 42186 Posted February 22, 2016 Solution Posted February 22, 2016 Hi, have you tried right click -> edit images? 2
JBL 8 Posted February 23, 2016 Author Posted February 23, 2016 Hi Luke, Bro, I am stumped...I hate to ask this, where would I go to right click and edit the images?
CashMoney 94 Posted February 23, 2016 Posted February 23, 2016 As in the image you posted, if you right click on the images you want to change, you can select "Edit Images". So open Emby in a web page, right click on Collections - Edit Images. HTH 1
JBL 8 Posted February 23, 2016 Author Posted February 23, 2016 As in the image you posted, if you right click on the images you want to change, you can select "Edit Images". So open Emby in a web page, right click on Collections - Edit Images. HTH Cool thanks, that worked!
